Old 05-08-2023, 10:27 AM   #1
jimvette59
jimvette59's Avatar
Default 8BA to 39 Trans.
How is a 39 type Trans. adapted to a 8 BA . My first time Flathead experience.
jimvette59 is offline   Reply With Quote
Old 05-08-2023, 10:32 AM   #2
Ken/Alabama
Ken/Alabama's Avatar
Default Re: 8BA to 39 Trans.
Truck bell housing that has the round transmission bolt pattern.
Old 05-08-2023, 10:38 AM   #3
tubman
tubman's Avatar
Or a '49 to early '51 Mercury "half-bell" which is stamped steel (which I prefer). Whatever one you get, make sure it comes with the proper starter plate; (the housings are much easier to find than the plates). The Mercury will not accomdate an 11" clutch (the truck bell will) which keeps you from making the mistake of using the heavy truck clutch, which you don't need.
Old 05-08-2023, 10:39 AM   #4
Newc
Newc's Avatar
Make sure you get the correct 'starter plate' with the bellhousing. Newc
Old 05-08-2023, 11:14 AM   #5
marko39
Should also need the 8rt truck water pumps and truck oil pan.
marko39 is offline   Reply With Quote
Old 05-08-2023, 11:18 AM   #6
marko39
If installing in a 30s car.
Old 05-08-2023, 12:41 PM   #7
V8COOPMAN
V8COOPMAN's Avatar
This is the '49 thru early '51 Mercury stamped steel half bellhousing that "tubman" mentioned above, along with the correct starter plate.
Coop
ANOTHER VIEW
Cast Iron Truck Version BELOW
Click Links Below __
T5 W/TORQUE TUBE
Old 05-08-2023, 03:27 PM   #8
tubman
tubman's Avatar
Hey Coop, the starter plates for the stamped Merc half-bell and the cast truck unit in your pictures look the same. Do you know if they are? (I'm a little short of knowledge on the cast bells).
Old 05-08-2023, 04:58 PM   #9
36fordguy
You forgot the front pulley change and the oil pump pick change 36fordguy
36fordguy is offline   Reply With Quote
Old 05-08-2023, 05:24 PM   #10
V8COOPMAN
V8COOPMAN's Avatar
Denny ..... Honestly, I was not SURE, but that tremendous site that "V8Bob" and partner put together eons ago states that "The starter plates can be interchanged on the cast & stamped half bells", although it should be noted that the truck bells (cast iron) will not have the tab with three bolt holes that the Merc plates have for bolting them to the pan. But what do I know?
Coopman
T5 W/TORQUE TUBE
Old 05-08-2023, 05:58 PM   #11
tubman
tubman's Avatar
As I have said before : "Actually, quite a bit".
Thanks for the info; it might make finding a missing plate for one a bit easier; I went throught the process many years ago when I stupidly bought an "Early to Late Flathead Adapter" from Speedway Motors for $89.95. It was a sandblasted Merc half-bell without a starter pate.
Old 05-08-2023, 06:55 PM   #12
51504bat
51504bat's Avatar
Just make sure you get one from a V8 not a six. They are different.
Old 05-08-2023, 09:22 PM   #13
Krylon32
I have a couple 6 cylinder bell housings I bought as V8's. Sellers didn't know the difference.
Krylon32 is offline   Reply With Quote
Old 05-09-2023, 05:51 AM   #14
JM 35 Sedan
JM 35 Sedan's Avatar
That is a common mistake that both sellers and buyers sometimes make. Maybe someone could post pics of a side by side comparison that points out the differences between the cast iron versions of the 6 cyl vs. the 8 cylinder truck bell housings.
John
Old 05-09-2023, 07:53 AM   #15
deuce5wndw
deuce5wndw's Avatar
It has been my experience that the cast bell plate is recessed like in Coop's photo for the diecast seal retainer to bolt to the rear pan bolts and the Mercury plate is flat. they will interchange but you wouldn't be able to use the retainer on the flat plat.
deuce5wndw is offline   Reply With Quote
Old 05-09-2023, 08:10 AM   #16
jimvette59
jimvette59's Avatar
I have the cast bellhousing on the engine and the fingers on the pressure plate do not reach the throughout bearing.
Old 05-09-2023, 08:43 AM   #17
19Fordy
19Fordy's Avatar
jimvette59: Many years ago (1972) I installed an 8BA in my 40 Ford. Read all the info. and links in the thread below about how it's done. 1949-53 Ford and Merc engine blocks are the same size.
https://www.fordbarn.com/forum/showt...ht=8ba+40+ford
Old 05-09-2023, 11:14 AM   #18
Krylon32
I started manufacturing the flat starter plates that work with the Merc bell housing. I've also bought quite a selection of starter plates from guys on the BARN and HAMB along with several Merc bell housings
Old 05-10-2023, 08:03 AM   #19
jimvette59
jimvette59's Avatar
Thank you for the reply. I am trying to install a 39 transmission on my 8 BA . My problem is the pressure fingers does not reach the through out bearing.
Old 05-10-2023, 08:08 AM   #20
jimvette59
jimvette59's Avatar
Thank you for the reply. I am trying to mate up a 39 transmission to a 8BA and the pressure plate fingers does not meet up with the throw out bearing.
