#21 | |
I've been known to do repairs for beer ...
#22 |
That's a good point. In my 59, the previous owner had installed an air conditioning unit. It's not working yet, but the compressor is hooked up under the hood and the hang on under the dash condensers right there. I'm hoping all I have to do is charge it with freon to get it going. Anyhow, if an alternator is a better option, then there's a good reason for swapping the gen for an alternator.
#23 |
I prefer to use all three wires myself. The one wire will self energize but it takes a bit more rpm than idle speed. The GEN light connection turns it on immediately.
#24 | |
Like manually oiling a bearing?
#25 | |
#26 |
#27 |
The folks that maintain their old generator systems have also been using reproduction voltage controllers when needed. They're not made near as well as the old originals. I would fear that the 12-volt alternator controllers that are currently produced may suffer the same problems. If a person has a problem with an internal solid state regulator then the problem can be pinpointed to the alternator itself in most cases. The parts to overhaul a 10si are still reasonable in price and so far they are relatively reliable. I've been using a 10si on my Ford 850 tractor for many years. I have one on my model A as well but it's a 6-volt conversion.
Generators work well and the old controllers last very well but they will need an overhaul after years of service. It's when a person installs a bunch of high amp accessories like air conditioning and such, that the alternator makes more sense. Last edited by rotorwrench; 04-18-2023 at 01:45 PM. |
#28 |
There is a little oil cap on the gen for the bearing area. 1 x per yr usually does it. a drop or two.
#29 |
| Thread Tools | |
| Display Modes | |
