Old 06-08-2011, 10:45 AM   #1
cpl624
cpl624's Avatar
Default Oil and anti-freeze question
I am a very new owner of a 1931 pickup. Over the last two weeks I have gotten it running to the point it does not make me nervous to leave my neighborhood with out my phone in my pocket. New fuel and electrical systems and it seems to do well. I need to get the timing set better, but that is another topic.
I would like to change the oil and anti-freeze as I am pretty sure they have not been changed since the truck was moth balled 25 years ago. I do not want to start a debate over what brand everybody is loyal to, but am interested in ratio and type of anti-freeze, and what type oil to use.
Thanks for any assistance to a very NEW owner.
Rick
Pleasant Hill, MO
cpl624 is offline   Reply With Quote
Old 06-08-2011, 11:40 AM   #2
Roadster Rich
Roadster Rich's Avatar
Default Re: Oil and anti-freeze question
My engine and radiator are original. I have never used antifreeze, since I never run in the winter. Only use a water additive to avoid corrosion. In the oil I have no filter and run 30 weight non-detergent. Change once a year, regardless of the low miles.
Roadster Rich is offline   Reply With Quote
Old 06-08-2011, 12:00 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Regular antifreeze 50% with water, and a 160* thermostat. 2 1/2 gallons is the right amount, as you want to leave 2 quarts capacity for expansion, otherwise it may just go out the overflow pipe anyway.
Any good detergent oil will work. I only add 4 quarts at changes.
Cut the barbbed portion off a plastic fitting and push it down from the top of the upper hose to hold the thermostat in place. No extra clamp needed, and you want the thermostat as close to the head as possible.
Old 06-08-2011, 02:08 PM   #4
bogdonj
bogdonj's Avatar
I run distilled water in both of mine throughout the summer/fall and when I put it away for the winter I drain the water out and pour antifree in it and drain it out. Never ever have had a problem and the block looks clean. (Cars are stored in a well kept garage) If your outside might want to look at antifree all the time.
bogdonj is offline   Reply With Quote
Old 06-08-2011, 03:29 PM   #5
Patrick L.
Patrick L.'s Avatar
I use distilled water with rust inhibitor [ I drain it for the winter].. As far as oil, I like 30 wgt AD[detergent], 4 qts ..
Old 06-08-2011, 03:40 PM   #6
Bruce Adams
Bruce Adams's Avatar
I like 15W 40 Shell Rotella oil, available at Walmart, since it is heavy on ZDDP zinc additive as in all oils from the 1940's.
I use Sierra brand anti Freeze here on Long Island in a 50:50 mix with distilled water all year round for its freeze protection, anti rust protection, and since Sierra brand propylene glycol is more "Foaming Resistant" than normal ethylene glycol blends.
Bruce Adams is offline   Reply With Quote
Old 06-08-2011, 05:03 PM   #7
cpl624
cpl624's Avatar
Tom,
So what degree thermostat are you putting in?
Old 06-08-2011, 05:22 PM   #8
ctlikon0712
ctlikon0712's Avatar
Tom, do you suggest drilling a hole in the outer rim of the thermostat for flow before engine warm up? If so, how large, or how many? I’ve seen this posted somewhere, and some new stats have them from the mfg.
ctlikon0712 is offline   Reply With Quote
Old 06-08-2011, 09:18 PM   #9
Tom Wesenberg
I drilled two 1/8" holes opposite each other in a 160* thermostat.
Old 06-08-2011, 10:10 PM   #10
Pilotdave
Pilotdave's Avatar
Just installed a thermostat. It came with a single 1/8" hole. I use 50/50 antifreeze and distilled water for coolant. Using SAE 30 non-detergent oil in the crankcase.
Pilotdave is offline   Reply With Quote
