Old 02-14-2023, 02:58 PM   #1
meteorgray
Default Zerk grease adapter fell into housing any harm?
While I was lubricating the throw out bearing the adapter fell off.
I tried fishing it out to no avail. Can it do any harm?
Thanks, Roger
meteorgray is offline   Reply With Quote
Old 02-14-2023, 04:34 PM   #2
31Tudor
31Tudor's Avatar
Default Re: Zerk grease adapter fell into housing any harm?
Yes, unfortunately it can! It can get wedged between the ring gear/ flywheel and either jamb it so it won't turn over, or crack the bell housing. You might be able to fish it out by dropping down the front radius ball. I have also gotten a starter bolt out with a magnet on a flex extension going down into the starter hole. The flex magnet might work going in through the front radius ball hole too. Definitely want to get it out of there before it turns into a bigger issue.
31Tudor is offline   Reply With Quote
Old 02-14-2023, 04:39 PM   #3
TMarsh
Hope it is magnetic, if not try duct tape on end of long flexible tool like magnet and I would go in thru starter opening. Fished out bolts before that way.
TMarsh is offline   Reply With Quote
Old 02-14-2023, 04:56 PM   #4
mleder
You may also try a shop vac where you get a smaller hose like a fuel line and use duct tape to keep it centered in the shop vacs big hose using a lot of tape to seal up the connection between the two. Feed hose down, power up vac and after repeated attempts you may suck it up or have it stuck to the end smaller hose , while vac is running pull it up. Just another suggestion that has worked sometimes- good hunting.
mleder is offline   Reply With Quote
Old 02-14-2023, 05:31 PM   #5
meteorgray
Thanks for all your replies and suggestions. I will try them all. Are there any tricks
or issues taking the radius ball out?
Old 02-14-2023, 06:17 PM   #6
Tom Endy
Tom Endy's Avatar
You can also put a handful of chassis grease on the flywheel through the starter hole and rotate it and hope it grabs the object.
Tom Endy
Old 02-14-2023, 07:58 PM   #7
WHN
If you drive the car you are asking for trouble!
As said above. Has to come out.
If it starts flying around, you are in for what could be a major problem.
Good luck.
Old 02-15-2023, 07:29 AM   #8
Wick
Wick's Avatar
My adapter is made of plastic.
Wick is offline   Reply With Quote
Old 02-15-2023, 11:23 AM   #9
JayJay
There was a letter I saw recently (Restorer magazine?) where a guy taped a strong rare-earth magnet (you can get them cheap at the hardware store or at Harbor Fright) to a piece of flexible plastic tubing (again, hardware store) and went fishing. Not only found the nut he was looking for but also a couple of washers. Of course, this won't work if your Zerk isn't magnetic...
JayJay
JayJay
San Francisco Bay Area
1930 Murray Town Sedan (under reconstruction)
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 02-15-2023, 02:40 PM   #10
meteorgray
The zerk is magnetic. Tried to get it out today no luck yet.
Went in with a magnet through the radius ball and the starter.
I did get a 1/4 bleeder bolt and washer out. Ordered a boroscope
from amazon and see if I can find it.
Thanks, Roger
Old 02-17-2023, 11:24 AM   #11
Dave in Petaluma
Dave in Petaluma's Avatar
I have used something like this with good results for this purpose. Having the magnet retractable allows you to get it into position easier.
https://www.magnetsource.com/collect...products/07588
Dave in Petaluma is offline   Reply With Quote
Old 02-17-2023, 11:33 AM   #12
The Master Cylinder
The Master Cylinder's Avatar
Thanks, Roger
My bore scope has a magnet on it. If you can see it you should be able to get it.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 02-17-2023, 04:28 PM   #13
31Tudor
31Tudor's Avatar
That is exactly what I have had luck with.
Old 02-19-2023, 04:30 PM   #14
meteorgray
Well I tried everything you all recommended but no luck. Took out the starter, radius ball
and throw out bearing cover. Tried flexible magnets and even bought a borescope.
Guess I will just hope it does not cause any damage. I did fish out a 5/16 by 1" fine thread
cap screw and a washer with tabs that bend over to lock. Wonder where that came from.
Roger
Old 02-19-2023, 06:31 PM   #15
J Franklin
J Franklin's Avatar
Usually after all that work I find the offending part under something on the garage floor a few days or months later.
Old 02-19-2023, 07:17 PM   #16
nkaminar
nkaminar's Avatar
Drop a bolt in a Model T engine/transmission and you have to take the motor out and apart. Don't ask me how I know.
Old 02-20-2023, 12:24 PM   #17
abachman3
abachman3's Avatar
The bolt you fished out and the tabbed washer are bendix starter bolts. Very common for them to come loose and end up as you found them.
abachman3 is offline   Reply With Quote
Old 02-20-2023, 12:43 PM   #18
nkaminar
nkaminar's Avatar
Another possible solution is to drag a rag through the housing using the ring gear on the flywheel. Just make sure you get all the rag back out.
Old 02-22-2023, 09:01 PM   #19
redmodelt
redmodelt's Avatar
Na! I have fished many things out of T engines, just by draining the oil and getting creative.
Old 02-23-2023, 08:33 AM   #20
History
History's Avatar
It could be inside the pressure plate if the engine hasn’t been turned over since you dropped it.
History is offline   Reply With Quote
