Old 01-31-2023, 07:09 PM   #1
BillW810
BillW810's Avatar
Default 1939 Ford window felt kit
I bought a project that had all the window felt removed. The project came with the Vintique kit for all windows. Most of the kit is obvious. Where does the roll go that is on the picture?
Thanks
BillW810 is offline   Reply With Quote
Old 02-01-2023, 07:51 AM   #2
marko39
Default Re: 1939 Ford window felt kit
i think it goes on the garnish mld.
marko39 is offline   Reply With Quote
Old 02-01-2023, 07:53 AM   #3
1942deluxe
1942deluxe's Avatar
The top of the door frame when I did my 42 but yours may be different.
Old 02-01-2023, 08:46 AM   #4
BillW810
BillW810's Avatar
There is a formed piece for the garnish molding.
Old 02-01-2023, 08:49 AM   #5
BillW810
BillW810's Avatar
That is my thought to protect/seal the top edge of the glass when closed.
Old 02-01-2023, 10:29 AM   #6
Planojc
Planojc's Avatar
With the tacks in the package it looks like its the cat whisker that fits on each side of the glass at the opening.
Planojc is offline   Reply With Quote
Old 02-01-2023, 11:39 AM   #7
BillW810
BillW810's Avatar
Likely also. Maybe top and sides. It is attached by adhesive on the underside.
I figured that was it. Not too many other places to put it. I just didn't to put it on and find out it's wrong.
Old 02-02-2023, 10:26 AM   #8
highbeams
highbeams's Avatar
When you install it, then it's felt. I don't know what it is before that . . . . . other'n notfelt.
highbeams is offline   Reply With Quote
Old 10-17-2024, 12:47 PM   #9
miniceptor86
miniceptor86's Avatar
It’s only a year and a half old. Not that old so I’ll try to revive it. 1939 Tudor standard sedan. My garnish molding the inside window frame has the felt or whiskers mostly flat. The window tracks/channels are good. I would just like the whiskers. Any sources with out buying tha whole shebang?
Cheers,
Jim&Sandy
McGregor, IA
miniceptor86 is offline   Reply With Quote
Old 10-17-2024, 03:03 PM   #10
Zeke3
Zeke3's Avatar
The roll of flat material looks like glass setting tape for the bottom of the window to the window channel.
Zeke3 is offline   Reply With Quote
Old 10-17-2024, 07:05 PM   #11
Karl Wescott
Karl Wescott's Avatar
"Cat Whiskers" around the window opening inside and out. Channels inside the door. That leaves the front/top/back of the door as raw steel. The roll of flocking is to be glued into the door to cover that raw area. This is typical of all Vintiques 1936 and newer kits.
Karl Wescott is offline   Reply With Quote
Old 10-18-2024, 11:48 AM   #12
JayChicago
JayChicago's Avatar
Karl
What are all those small flat-head screws in the Vintique package used for? I know the staples are for the cat whiskers, which were originally stapled to the body and garnish molding. Are the screws an alternative to the staples, because staples are so very difficult to use?
