Old 06-06-2011, 07:07 PM   #1
Jim in S.C.
Default rpm math question
OK mathematicians, Can anyone tell me how many rpms a engine would be turning if you have a manual three speed transmission (no over drive)and you have a 4.44 differential and tires that are twenty eight inches in diameter and you are traveling forty miles per hour. Once again whats my rpms?
Wow, I have a headache trying to figure this out, HELP!
Jim in S.C. is offline   Reply With Quote
Old 06-06-2011, 07:13 PM   #2
Max
Default Re: rpm math question
2200 RPM would be 41.3 MPH
Max is offline   Reply With Quote
Old 06-06-2011, 07:23 PM   #3
19Fordy
19Fordy's Avatar
Use this.
http://www.westerndiff.com/rpm.html
Old 06-06-2011, 08:00 PM   #4
oldford2
oldford2's Avatar
I added a small tach below my dash and use a gps to check my speedometer accuracy and get true speed.
oldford2 is offline   Reply With Quote
Old 06-06-2011, 08:25 PM   #5
Flat Ernie
Flat Ernie's Avatar
2141 RPM @ 40 mph
Daddy always said, "If yer gonna be dumb, you gotta be tough" and I'm one tough sumbitch!
T5 Tech
Flat Ernie is offline   Reply With Quote
Old 06-06-2011, 08:54 PM   #6
4dFord/SC
4dFord/SC's Avatar
There are three kinds of people in the world: those who are good with numbers and those who are not.
4dFord/SC is offline   Reply With Quote
Old 06-06-2011, 08:57 PM   #7
john hamilton
john hamilton's Avatar
It's just steps, not hard if you pay attention:
(tire dia. in inches X 3.1416)/ 12" per foot = 28 X 3.1416/12 = 7.33' traveled per revolution
5280' per mile/feet traveled per revolution = 5280/7.33 = 720 revolutions per mile
revs of the tire per mile X gear ratio = 720 x 7.33 = 3197 engine revs per mile so at 60mph you would be wrapped out.
correct for 40mph which is less than a mile per minute by multiplying engine revs per mile X actual mph/60 = 3197 x 40/60 = 2132 engine rpms at 40 mph.
With your tires and gears you can apply this correction to any speed by putting your "actual mph" in the equation above.
john hamilton is offline   Reply With Quote
Old 06-06-2011, 09:01 PM   #8
john hamilton
By the way, my equations above agree with Flat Ernie and Max who gave you the answer. Note 3196 x 41.3/60 = 2200 rpm
Old 06-07-2011, 09:03 PM   #9
Jim in S.C.
Thanks for all the answers. I put the calculation web sites in my favorites
Jim in S.C.
Old 06-08-2011, 08:05 AM   #10
Jerry Parr WI
Jerry Parr WI's Avatar
A minor correction if you want is to use the rolling circumference of the tire. Because the weight of the car flattens the tire at the road the car travels slightly less distance than the tire diameter would indicate. Lower air pressure or more weight equals less distance per revolution. Mark the tire and the road and measure one revolution.
Jerry Parr WI is offline   Reply With Quote
