Old 01-27-2023, 06:01 PM   #12
pjdeb
pjdeb's Avatar
Default Re: Backfire! Help! So frustrated!
Originally Posted by Bill G View Post
Backfires can be from running lean. You might also check for good gasket seal around the manifolds and check for cracked manifolds and make sure that the vacuum port for a vacuum wiper is not opened up.
Thank you for the replies.
Update: compression 60, 62,62,64.
I do not think it is manifold or vacuum leak as it runs well at idle.
I checked two zenith carbs for float level. Both seem to be about 3/4 to the seam using the gage tube from the drain plug. I mean need shims. I will order, but I do not think that is the real problem.
Ran some seafoam into carb at high revs. Run for a couple of minutes.
Put some MMO into cylinders. Turn it over with the crank. Put some more in to sit overnight. In the morning I will smoke out the neighborhood.
After that I will try yet another set of plugs. Running Autolite 3076. Probably not the best, but I have run them for a few years. They run black. GAV is completely closed.
I hear what you are saying about "new" parts. I do not have a way to test them, unfortunately. I am getting good spark from the coil when holding the wire end close to a stud.
I do appreciate your help.
pjdeb is offline   Reply With Quote
