Old 01-24-2023, 09:41 PM   #21
jeepguy1948
Default Re: How nat of you are using engine/motor pans?
I apologize for my mispelling of the title, it should ready “How many of you” I don’t know I missed that
jeepguy1948 is offline   Reply With Quote
Old 01-24-2023, 10:00 PM   #22
Synchro909
Synchro909's Avatar
I can see how the mounting points would crack so I wonder about mounting them on rubber like they use on the number plates, indicators etc on motor cycles.
It's easy to make a double ended bolt for holding the sump and to attach the pans. That covers that side of them. Weld a nut on the inside of the chassis (or tap the hole) where they attach there. Put a rubber sleeve above and below the pan all held in place by a nut and washer. I'd use a Nylock nut, I think. That should leave them mounted softly enough that they won't crack.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
If I am not in trouble, I've done something wrong.
Old 01-24-2023, 10:14 PM   #23
jeepguy1948
My ‘28 RPU does not have them they were long gone when I got it.
Old 01-25-2023, 07:53 AM   #24
Keith True
Keith True's Avatar
I've used double ended oil pan bolts from old Chevy V-8's.Half is to hold the oil pan,and the other half was to hold battery cable brackets.I would take them from off engines in the scrap motor pile at the junkyard.
Old 01-25-2023, 09:38 AM   #25
Aretino
Aretino's Avatar
They are on mine
Aretino is offline   Reply With Quote
Old 01-25-2023, 09:54 AM   #26
Seth Swoboda
Seth Swoboda's Avatar
I think the engine bay looks naked without them. I like them on V8 Fords as well. Completes the look of the engine bay. I find that they are not a hassle. Who is taking them on and off so often?
Old 01-25-2023, 11:08 AM   #27
Gufshoz
Gufshoz's Avatar
I used to have issues with overheating. When I put the pans on I had problems with running too cold: thus, I now have a thermostat that keeps her at a nice 160 f.
Gufshoz is offline   Reply With Quote
Old 01-25-2023, 11:23 AM   #28
katy
katy's Avatar
Methinks 160° is a bit low, I prefer 180°.
Old 01-25-2023, 11:29 AM   #29
MAG
MAG's Avatar
X2 on post 20.
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
Old 01-25-2023, 11:50 AM   #30
jeepguy1948
Synchro, I’d buy yours but well, the shipping might be a deal breaker LoL.
Old 01-25-2023, 08:45 PM   #31
Synchro909
Synchro909's Avatar
Shipping would make them too expensive but that's a problem we face all of the time.
Pity we can't drive there ourselves to pickup stuff. In fact, we can't drive to any other country.
Old 01-26-2023, 11:15 AM   #32
rackops
rackops's Avatar
I use them in my car. I prefer the look and have had no issue with them.
Member, MARC
Current owner, 1928 RHD Australian-built Phaeton CA4752 "Felicity"
Former owner, 1931 Victoria, 1929 Phaeton, 1929 Fordor
rackops is offline   Reply With Quote
Old 01-27-2023, 02:48 AM   #33
CarlG
CarlG's Avatar
Originally Posted by ndnchf View Post
I put them on and have no issues. The engine stays cleaner and the engine bay looks more finished. I tapped the frame holes so the bolts can be more easily installed. It makes removal and replacement a breeze.
Same here, tapping the frame is a "no brainer!"
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 01-27-2023, 09:40 AM   #34
Seth Swoboda
On the V8 models Ford used a cad plated self tapping screw. Pretty easy to install.
Old 01-27-2023, 10:17 AM   #35
David in San Antonio
David in San Antonio's Avatar
Did Ford use pans throughout A production? I think I heard they were discontinued, then added back. True or malarkey?
Late ‘30 Deluxe "Wretched Roadster"
1931 Slant Windshield Fordor “Earl Gray”
Alamo A’s Club
David in San Antonio is offline   Reply With Quote
Old 01-28-2023, 06:55 AM   #36
Chris in WNC
Chris in WNC's Avatar
early in 1928, Ford discontinued the fan shroud.
if engine pans had no useful function, they would have been discontinued also.
anything to reduce production cost.
the car looks better with them installed.
when I see a Model A for sale without engine pans I assume the seller does not really know what they are doing, makes the entire car just slightly suspect.
no more model As for now........
Chris in WNC is offline   Reply With Quote
Old 01-31-2023, 10:10 AM   #37
A model Thom
A model Thom's Avatar
I've never seen them on an Australian built car, I'd never even heard of them until I joined a few American based Facebook groups/forums, doesn't mean they never had on rhd model a's, I'm just saying I've never seen them
A model Thom is offline   Reply With Quote
Old 01-31-2023, 11:49 AM   #38
Flathead
Flathead's Avatar
Are they a pain? Yes. Do I use them? Absolutely!
The Model A was a well designed package, when you start changing things you upset what was laid out to be a harmonious design. The pans are a part of cooling, electrical grounding, and dirt being sucked into the carb. and more.
Flathead is offline   Reply With Quote
Old 01-31-2023, 03:55 PM   #39
ursus
One solution to the problem of fracturing fan blades is the use of plastic fans. I wonder if sturdy and squeak-free engine pans could be formed from 1/8 inch black polyethylene plastic?
Old 02-02-2023, 09:31 AM   #40
Canton_Model_A's
Canton_Model_A's's Avatar
just ordered my 2 Black powder coated ones from Snyders, should be here tomorrow, but lots of luck me puttin' them in anytime soon. the Snow has to go away first and get a tad bit warmer.
Canton_Model_A's is offline   Reply With Quote
