Old 01-19-2023, 02:58 PM   #1
olhkry
Default Re: 1947 Hore Ring
Trying to get to the button under the ring. The horns work (removed and hotwired) but, when re-installed, they don't. It appears that the wire from the horn relay to the horn button has been pulled out.
olhkry is offline   Reply With Quote
Old 01-19-2023, 04:01 PM   #2
Kube
Super Moderator
Kube's Avatar
The entire assembly comes off as one piece. In other words, the stainless ring and spokes as well as the button.
Once you have this assembly removed, you will quickly see how the button is held in the ring. Easy to remove.
