Old 06-04-2011, 07:44 AM   #40
john in illinois
john in illinois's Avatar
Default Re: Driving & then COUGH COUGH & Died..10 min later start & Fine..& Died again.
I had the cap vent problem described by Pat. I drilled through the original vent hole in the center piece. I tapped the hole for a small screw and locktited in place. This locked the gasket to the cap center so it could not rotate to block vent.
I then drilled a new vent hole on the opposit side of the original hole. Be careful to only drill through the center and not the outer cap.
This has worked well for several years .
John
john in illinois is offline   Reply With Quote
