Old 11-28-2022, 09:04 PM   #1
3twinridges
3twinridges's Avatar
Default 7ra v8 distributor
Thanks guys for the guidance on color. I painted the distributor cast iron and it looks great. So far new bushings, new breaker plate, wiring and points. Condenser checks out within specs. Waiting on a new vacuum canister to mount on the bench before I install the shaft/gear.
Before I insert the wick and oil cap, should I inject some oil in the hole first? Or just install the wick and oil that?
JB
File Type: jpeg 85B9A284-7D82-4001-B3C8-F27C200C8256.jpeg (90.0 KB, 233 views)
File Type: jpeg 1C14C8F2-0644-4BC4-A8A2-27D664C4C710.jpeg (88.8 KB, 230 views)
3twinridges is offline   Reply With Quote
Old 11-30-2022, 04:42 PM   #2
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Default Re: 7ra v8 distributor
Hows the wiring under the breaker plate ????? I have some new ones
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 11-30-2022, 04:47 PM   #3
petehoovie
petehoovie's Avatar
JB
Old 11-30-2022, 05:43 PM   #4
3twinridges
It looks good Bubba, all new with new hardware, appreciate it though.
JB
Old 12-16-2022, 09:43 PM   #5
3twinridges
Put the distributor on the sun machine tonight. Set the dwell but couldn’t get the advance right on the second vacuum setting of 1.7. I think the springs are weak so I will have to source new ones. The springs were pretty rusty, so I soaked them in evaporust, but I think they are too far gone. I have the lugs on the plate adjusted to the max distance and I am still getting about 7 degrees of advance at 1.7 vs the spec of about 5 degrees. Will report back with new springs.
JB
Old 12-16-2022, 09:54 PM   #6
Lawson Cox
Lawson Cox's Avatar
Send it to Bubba and be done with it. My 2¢.
Old 12-17-2022, 12:33 PM   #7
Tim Ayers
I don't think Jim/Bubba is taking on work at this time.
Old 12-17-2022, 12:47 PM   #8
Merc Cruzer
Merc Cruzer's Avatar
Yes, for the answer to squirt oil in before reinserting the wick.
If you have a Sun machine, then just order the new springs, then finish setting up the distributor yourself. It sounds like you have it under control.
I can't over state how much of a difference it made, when I rebuilt mine and had them set up on the Sun machine. New bushings, made all the difference in the world, along with the new wires, point and condenser.
Merc Cruzer is offline   Reply With Quote
Old 12-17-2022, 04:11 PM   #9
3twinridges
Agreed, that 2-3 degrees of advance against spec has to make a difference. I have a set of 8EQ springs. Any idea why the 7RA distributor has two different springs and the 0BA has two 8EQ springs? The vacuum canister and breaker plate are the same. Seems like the 8EQ springs should work….
JB
Old 12-20-2022, 07:25 PM   #10
Merc Cruzer
I guess the quick answer is that they define the curve… if you advance the mechanism to it’s full extent you’ll see the spring closest to the vacuum can is parallel to the line of travel and the spring furthest away is oriented at 45 deg. The close spring affects the entire range of the advance the one at 45 is biased more toward the upper end of the curve.
