Old 10-11-2022, 08:15 AM   #1
russcc
Default Deleting selected PMS
I want to cleaned out my PM box, but not delete them all. How to ? Thank you.
Old 10-11-2022, 09:36 AM   #2
TJ
TJ's Avatar
Default Re: Deleting selected PMS
Just check the box on the right side next to the message. Then scroll down to the bottom box put delete in that box and hit 'go"
Old 10-11-2022, 09:44 AM   #3
russcc
That's fine for the current ones, but I have bunch to delete, like 300 or 400, so I need to open them and pick & choose the ones by checking them off to delete.
Old 10-11-2022, 09:51 AM   #4
Tim Ayers
I believe you can "batch" delete them. they are grouped by month or dates if I recall correctly. You click the block next the group heading and it will check all of those PM's in that grouping and you can delete them all for that section.
Old 10-11-2022, 11:35 AM   #5
flatford8
flatford8's Avatar
Yes you can batch delete. The number at the top shows how many in the batch. Check that box and all mesg will be checked in that batch. Go to the bottom and click the box, change to delete, and hit go. All checked will be deleted. If you want to save one in that batch, uncheck each one to save before you go to delete. Practice on a couple that you don’t want to save, just to be sure you have the process correct…….. Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
Old 10-12-2022, 07:34 PM   #6
russcc
Thank you all. The practice run is good idea.
Old 10-13-2022, 02:41 AM   #7
Randy in ca
Randy in ca's Avatar
If it makes it any easier to sort thru them, you can also have them sorted by either Title or Sender rather than by date. You can also create your own custom folders (as well as the Inbox and Sent) to file anything you want saved into.
Randy in ca is offline   Reply With Quote
