Old 10-10-2022, 06:54 PM   #1
russcc
Default Help identifying the radiator in the '40
I don't belief the radiator in my '40 is original, although it looks like it belongs and has been in there for awhile. Thank you.
Old 10-10-2022, 07:07 PM   #2
Kube
Super Moderator
Kube's Avatar
Default Re: Help identifying the radiator in the '40
That's an aftermarket replacement. Might have been in there a log time but sure didn't come from the factory.
Picture attached is what the radiator should appear as in your car. Even though this particular one is in a '40 pickup, it's identical to the passenger cars. The exception? The 60HP equipped vehicles had a very different radiator.
Old 10-10-2022, 07:14 PM   #3
Ken/Alabama
Ken/Alabama's Avatar
Look around the top tank to see if you can find a number stamped in it. I have one similar but not just like it in one of my 40s and it has a 91A number stamped in it. It’s a service replacement radiator. It’s not factory correct but it cools.
File Type: jpeg 77370E11-B875-436E-B523-3B7D71BC1DB0.jpeg (83.5 KB, 55 views)
File Type: jpeg 5BAEA9E2-0C48-4B60-9EA2-ED91FF043D65.jpeg (96.6 KB, 60 views)
Old 10-11-2022, 05:39 AM   #4
richard crow
filler cap should be on drivers side also split core there was a nice one for sale at hershey
richard crow is offline   Reply With Quote
Old 10-11-2022, 06:54 AM   #5
L-head
Could it be out of a 41 Ford? I think that a 41 will fit a 40 with no mods. I also think a 41 will hold 1 quart of water than a 40 will.
L-head is offline   Reply With Quote
Old 10-11-2022, 08:13 AM   #6
russcc
Thank you al for your help. The side fill & spilt core are good cues. I will look for the number stamped on it. I had the radiator cleaned, pressure tested and a side strap re-soldered by Starfish Radiator, and it cools just fine. It looks & works good but I was just curious as what it was, as I knew it probably wasn't original. I though it might be a '41 also.
Old 10-11-2022, 09:55 AM   #7
pistonbroke
It's looks identical to my 41 pickups. Tim
Old 10-11-2022, 07:08 PM   #8
deuce_roadster
deuce_roadster's Avatar
I had a service replacement that looked exactly like that, the 91-A was not stamped in but was embossed and the characters stuck out. Sold it to a club member that needed a 39 radiator (but not for the concourse).
