Adding to the thoughts on the The Perfect Street Engine I would look into a vacuum pump electric operated. Reducing crankcase pressures will increase output and at no cost in power grabbing when a good alternator is used to feed the needed voltage to run the pump.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587 Last edited by Ronnieroadster; 10-07-2022 at 12:42 PM. |
Hmmm, I would expect that a BAD alternator would be the one that does not rob power! A "good" alternator is the one that robs engine power to generate electrical power. (No such thing as a free lunch!)
| Thread Tools | |
| Display Modes | |
