Old 10-04-2022, 07:22 PM   #1
ssffnomad
ssffnomad's Avatar
Default Ford H2O Heater
Hello, please help with Heater info.
This is in our 39’ Deluxe. What year is it ?
It has been wired to 12V. Fan works good in both directions.
Does it matter which heater hose gets hooked up as far as circulation ?
One hose comes off pass side lower radiator hose.
Other off intake manifold.
T/Y. Stretch
ssffnomad is offline   Reply With Quote
Old 10-04-2022, 07:46 PM   #2
Zeke3
Zeke3's Avatar
Default Re: Ford H2O Heater
The fitting on the cylinder head should supply the heater and should be attached to the lower connection on the heater core. This is to prevent air being entrapped in the core. The coolant return from the heater is plumbed from the upper connection on the heater to the lower radiator hose.
Zeke3 is offline   Reply With Quote
Old 10-04-2022, 07:58 PM   #3
ssffnomad
ssffnomad's Avatar
Old 10-04-2022, 08:03 PM   #4
ssffnomad
ssffnomad's Avatar
Zeke, that is the way previous owners had it plumbed.
T/Y
Old 10-04-2022, 08:29 PM   #5
Lawson Cox
Lawson Cox's Avatar
What is an H 20 hearer? LOL
Old 10-04-2022, 09:27 PM   #6
ssffnomad
ssffnomad's Avatar
E95117BB-3567-4BC4-947D-E457FFC10526.jpg.
I am going to Bed
Old 10-04-2022, 10:29 PM   #7
Lanny
Lanny's Avatar
QUOTE : It has been wired to 12V. Fan works good in both directions.
Just a note to say, The fan will only blow air correctly in only ONE of the two directions.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
Old 10-04-2022, 10:29 PM   #8
meric42
meric42's Avatar
That's a '41 - '48 heater, here are the installation instructions for you.
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP
Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand
http://www.fordbarn.com/forum/album.php?albumid=580
meric42 is offline   Reply With Quote
Old 10-05-2022, 08:30 AM   #9
deuce_roadster
deuce_roadster's Avatar
That is a later heater, probably 42-48. A 39 heater looks VERY much like a 40 except for the color and the shape of the 2 handles and possibly the "toe guard" at the bottom.
Old 10-05-2022, 08:49 AM   #10
Automotive Stud
Automotive Stud's Avatar
It's a 42-48 heater. As long as one hose is hooked to the head and the other goes to the lower hose as described the heater doesn't care which line goes where on it. Reversing the fan motor forces air through the defrost ducts as I'm sure you know but apparently some commenters don't.
Automotive Stud is offline   Reply With Quote
Old 10-05-2022, 09:20 AM   #11
ssffnomad
ssffnomad's Avatar
Meric, thanks for posting info.
Stud , yes it spins / blows good in both directions.
We kind of knew it was not 39’ Heater, because the bottom door can never be open and be able to shift the trans.
Stretch
Old 10-05-2022, 02:54 PM   #12
ssffnomad
ssffnomad's Avatar
1st test drive with Heater plumbed up & 12V .
Should of wrapped a couple of 🌭’s in foil, and put on top of heater box.
Stretch
Old 10-05-2022, 03:42 PM   #13
4dFord/SC
4dFord/SC's Avatar
I've sometimes been an H2O hearer after swimming.
4dFord/SC is offline   Reply With Quote
Old 10-05-2022, 04:02 PM   #14
ford38v8
ford38v8's Avatar
I think some (most) of us have way too much time on our hands…
Alan
Old 10-05-2022, 04:07 PM   #15
5851a
When I was young anything with a heater was a plus in the winter. I at one time cut apart an under-dash AC unit and ran coolant through it. talk about roasting chestnuts on an open fire. S!it howdy them flatheads will make some btu's with Tstats. Sorry probably went too far.
5851a is offline   Reply With Quote
