Yes you can delete the filter by installing a plug but if it were me I would try to fix the leak first. Thousands of these are in use that don’t leak so something is not right. Check to see if there is a restrictor fitting on inlet which reduces the pressure in the canister. It should have a .060 hole in it.
#2 | |
Super Moderator
#4 | |
The restrictor properly placed in the inlet side of the filter canister will lower the pressure in the can. It will raise the pressure to the engine and the oil gauge because less oil will flow through the filter and more will be supplied to the engine oiling system. Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick) '30 Model A Speedster '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" 302
#5 | |
Super Moderator
Anyone that has installed one of these filters without a restrictor had found all too soon, that the oil pressure had dropped, sometimes quite radically. The original poster most likely has an issue with the gasket seating properly. I highly doubt there is any pressure issue at all.
| Thread Tools | |
| Display Modes | |
