Old 09-22-2022, 09:04 PM   #1
dad's deuce roadster
dad's deuce roadster's Avatar
Default Adjustable temperature switch
We continue making progress on the roadster. Does anyone know of an adjustable temperature switch that can go into the head? Lacking that, what would the proper temperature be for a switch that will kick in the electric fan? I've heard 200 F, but seems a tad high.
Thanks,
dad's deuce roadster is offline   Reply With Quote
Old 09-22-2022, 09:43 PM   #2
40cpe
40cpe's Avatar
Default Re: Adjustable temperature switch
I haven't seen an adjustable switch to screw into the head. I do have a 195 degree switch in the head of my 8BA engine. It controls a Cooling Component fan that begins to bring the temp down quite quickly to the 180 degree thermostats.
Old 09-23-2022, 12:32 AM   #3
deuce lover
deuce lover's Avatar
There is one that has a probe that replaces the petcock in the bottom of the radiator.Parr Automotive used to sell them.
Here is a link:
https://www.parrautomotive.com/index...od/prd8365.htm
Old 09-23-2022, 10:20 AM   #4
Thanks, for the replies thus far. I'll check them.
Old 09-23-2022, 12:15 PM   #5
5851a
If you have a pick and pull, any Ford Escort from the 80's has a fan switch at the end of the Tstat housing. 1 wire grounding type switch. Turned fan on around 200. Other electric fan Fords had them also but can't remember location of them all. Mid to late 80's Mustangs with 4-cylinder electric fan had sensor in the heater supply hose.
5851a is offline   Reply With Quote
Old 09-23-2022, 02:48 PM   #6
Gene1949
Gene1949's Avatar
There is no point in running the fan if the radiator bottom temp is under 180 degrees.
Most people put the temp switch in the bottom tank
Gene1949 is offline   Reply With Quote
Old 09-30-2022, 11:47 AM   #7
Good info, thanks
Old 09-30-2022, 07:06 PM   #8
36fordguy
got one from speedway put iton my 36 PU works great set to any temp - control fan on/off 36fordguy
36fordguy is offline   Reply With Quote
Old 10-08-2022, 07:29 PM   #9
Just a note, opted to go with American Volt single wire switches, planning to use in one of the heads. Grabbed 2, one at kicks in at 190, the other at 200. both cut out 15 deg lower than the the on temp. We'll try the 190 first and see where the water temp actually is.
Old 11-07-2022, 09:13 PM   #10
An update. Ran with the 190 F temperature switch. Idling to full warm up fan kicked in right at 190 on the temp gage on head port, fan came on, temp dropped in a couple minutes and fan shut down. Working well.
Took car out for a short run on a colder day. Ran about 4 miles. Engine never topped 140.
Old 11-08-2022, 07:38 AM   #11
flatford8
flatford8's Avatar
Unless I missed where you mentioned this, are you not running thermostats? Your engine would be happier at 185*- 190*.....the switches you found seem to be the answer....Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
Old 11-08-2022, 11:33 AM   #12
JayChicago
JayChicago's Avatar
Agree with previous post by flatford8. I think running that cool is not good for your engine. I would install 180 thermostats, then tweak the fan switch.
Old 11-08-2022, 07:24 PM   #13
Lawson Cox
Lawson Cox's Avatar
This wording of this posting reminded me of my childhood days, you know, way back when ass whoopins were in vogue.
The size of the switch varied or was adjusted according to just how "hot" Daddy was over what I had just done. Get the picture?
It seems that the "time out" generation is not faring quite as well as the ass whoopin generation.
Old 11-08-2022, 08:00 PM   #14
Thanks all. I did feel the temp staying cool was not good for the engine for all the reasons posted. And just to be save, I'll ask - if I understand correctly, the thermostats, e.g. the $10 ones at speedway, can just sit on the top of the head ports and the hoses will keep them in place. Is that right
Old 11-09-2022, 04:55 AM   #15
flatford8
flatford8's Avatar
Some people use another piece of hose inside both rad hoses to hold the t-stat in place. Some use PVC or small wires from the t-stat and pinch them between the hose and the neck on the head. A quick search should show multiple ways of keeping it in place.......Mark
Old 01-13-2023, 09:05 AM   #16
Just a wrap note on this thread. We installed 180 t'stats. We went to using some stainless tubing between the hose off the heads and into radiator. We just lest the t'stats bump up to the tubing. We did drill a 1/8" hole in each t'stat to allow some flow before than open and to give air an escape route.
The setup is working well. The t'stats open and a few minutes later the fan with it's 190 F temp switch will kick in. Amazing to me is that the original temp gage readings are spot on with the opening of t'stats and the fan kicking in.
Old 01-14-2023, 03:05 AM   #17
aussie merc
aussie merc's Avatar
I gather you have a 59A [center of head outlet] yes the original hoses had a lip moulded into them to keep the stats in place unfortunately replacement hoses dont have this so the fun begins. I personally went to stainless pipes and jam them down on the stats and clamp in place . Others use wire or modify the stats to keep them in place there are lots of posts on here about this so its up to you how you do this.
aussie merc is offline   Reply With Quote
