Old 09-27-2022, 06:02 PM   #1
Ol' Ron
Ol' Ron's Avatar
Default The perfect "street engine"
I think it's time to build the perfect street engine! Good usable power and economy at a minimum of cost. There are enough guys here that build engines and have plenty of experience. I'm working on one now.
Gramps
Old 09-27-2022, 06:07 PM   #2
19Fordy
19Fordy's Avatar
Default Re: The perfect "street engine"
That's great news Ron. Take plenty of photos and let us follow along on your build. Your knowledge is gold.
Old 09-27-2022, 06:44 PM   #3
richard crow
there all ready is one. a stock eng. as ford made it
richard crow is offline   Reply With Quote
Old 09-27-2022, 07:00 PM   #4
19Fordy
19Fordy's Avatar
So true, but as Ford ceased making them, it would be neat to see how Ron applies his years of skill and knowledge to build an affordable and reliable flathead in 2022. Hopefully, an 8BA.
Old 09-27-2022, 07:53 PM   #5
5851a
This will be interesting. A perfect engine will be different from person to person and depends on vehicle intended for. As a youth, perfect would have been wild cam tire burning coupe, as older now a high torque cross country 50's Mercury trips my trigger.
5851a is offline   Reply With Quote
Old 09-27-2022, 08:59 PM   #6
Pete
First, you must define perfect and only one thing is perfect, so the term for this engine under discussion will be "near perfect".
It should be free.
It should have a flattop power curve.
It should make 300 hp on cheap gas.
It should have an adjustable idle. Smooth for commuting and lopey for cruise nights.
It should have exhaust cutouts. Noisy for cruising. Quiet for commuting.
It should have lots of chrome.
It should last 100K miles.
Old 09-29-2022, 07:27 AM   #7
Ol' Ron
Ol' Ron's Avatar
Be Nice if I could have some help here Pete, gota keep these old engines runnin. I'm not capable to build an engine and post pics and videos. All My grandchildren have moved on.Jere's my suggestions. In JWLs book he has the output of the stock 239ci engine at 150 lbs of torque @ 2,000, and 80 hP @ 3000.
Boring the block to 3 5/16 will add 19ci and aprox 10ft lbs of torque Plus one point in cR angle milling the head .07- will also increase Cr by one point. The EAB cylinder head has 74cc chamber volumn wnd will give the 258CI engine aprox 7.7 CR all this will work verywell with the stock Load a matic ignition. And the engine will look as stock as the day it came from the factory.
Gramps
Old 09-29-2022, 08:14 AM   #8
lotsagas4u
Ron, what motor oil do you run in these engines? 10/30 is what you prefer? What brand?
Thanks
lotsagas4u is offline   Reply With Quote
Old 09-29-2022, 08:40 AM   #9
tubman
tubman's Avatar
It should be free.
The only thing that even comes close is a 350 SBC!
Old 09-29-2022, 04:43 PM   #10
Pete
Gramps
No sweat. I agree almost 100%. Only thing I would change if it was in the budget is, use an aftermarket all mechanical ignition.
Old 09-29-2022, 05:52 PM   #11
Ol' Ron
Ol' Ron's Avatar
Yes 10/30 is a fine oil from most'r brands. Pete thats true but when using the stock vam the Load a matic is almost fool prof. How many people hee have a AF meter. I even loan out the timing light KISS is my moto
Gramps
Old 09-29-2022, 05:55 PM   #12
lotsagas4u
Ron, thanks for the reply, you are not much into the zinc needed crowd I gather.
Old 09-30-2022, 08:03 PM   #13
Ol' Ron
Ol' Ron's Avatar
Stock engines don;t have much valve spring pressure, so any lack of special addatives don't have much vale. Are they better, yes. Are they necessary, I'really not sure?????
Gramps
Why are there two perfect engine threads????????
G
Old 10-01-2022, 02:31 AM   #14
V8COOPMAN
V8COOPMAN's Avatar
G
Look at who is the FIRST POSTER in EACH one of those threads...none other than some guy named "Ol' Ron".
Click on the two links BELOW. Two different threads for sure. SAME guy started BOTH of them.
Coop
https://www.fordbarn.com/forum/showthread.php?t=318757
https://www.fordbarn.com/forum/showthread.php?t=318763
Click Links Below __
T5 W/TORQUE TUBE
Old 10-01-2022, 04:48 PM   #15
Ol' Ron
Ol' Ron's Avatar
The posts were more than an hore apart. I certenly didn't do that???
Old 10-01-2022, 06:02 PM   #16
Flathead
Flathead's Avatar
Maybe you were hacked and the Russians want to know how to build the perfect Flathead?? Well....just a thought.
Flathead is offline   Reply With Quote
Old 10-02-2022, 01:20 PM   #17
Ol' Ron
Ol' Ron's Avatar
I lov it!!!
Old 10-03-2022, 05:58 PM   #18
mhsprecher
mhsprecher's Avatar
So good it repeated itself.
1910 Model T Touring
1924 Model T Coupe
1928 Model A Roadster
1930 Model A Town Sedan
1939 Deluxe Fordor
1945 pickup
1951 Custom convertible
mhsprecher is offline   Reply With Quote
Old 10-03-2022, 09:55 PM   #19
ken-r-mer
A flatty blower like fromTom Roberts with a mild 6 lb boost(pricey but nice).
ken-r-mer is offline   Reply With Quote
Old 10-05-2022, 07:11 AM   #20
Ol' Ron
Ol' Ron's Avatar
How about an old Mculla from the 50's? Blow thru 4bl, and you have a 200hp "Stocl" engine.
