What I do is once the front main drive is out I then bump the end of the main shaft where the u joint goes, with a rubber mallet to push the main shaft through the rear bearing. The snap ring on the bearing prevents the bearing from moving with the main shaft.
| Thread Tools | |
| Display Modes | |
