Old 09-15-2022, 06:52 AM   #1
Granny
Default Piston Size
I have a C1BA engine that had 0.020th pistons which needs rebore, What size
pistons would you guys recommend to replace the old ones.
Thanks in advance
Granny
Granny is offline   Reply With Quote
Old 09-15-2022, 07:28 AM   #2
kurt v
Default Re: Piston Size
If you are good with what you had just go to the next size that the motor needs to be bored.
kurt v is offline   Reply With Quote
Old 09-15-2022, 07:56 AM   #3
Ol' Ron
Ol' Ron's Avatar
For a general rebuild, the machine shop can determine the minumn bore size to clean up the cylinders. For a street rod, I'd go with a 3 5/16 bore and a .07-" angle milled heads. Using the stock cam this will increase the low and mid range torque, raise the Cr to over 8:1 thus increasing gas mileage and performance in an otherwise stock engine with out increasing the cost of the re build much. Be nice if you could buy auto thermatic pistons, but I don't know if anybody makes them any more. I built a 296ci engine back in the 90's with a set of 3 3/8 x 4 1/8 (296") with stock style 4 ring steel strut pistons. What a fantastic street engine that was as still is.
Gramps
Old 09-16-2022, 08:37 AM   #4
Granny
Why I asked the Question was I am trying to find some piston here in Aussie
My engine is going into a hot rod so not to worried about Economy I have flatattack racing Heads and a Crow cam to go in it
Granny
Old 09-16-2022, 05:36 PM   #5
flatjack9
flatjack9's Avatar
.060 over pistons are generally easy to find.
Old 09-16-2022, 08:04 PM   #6
Granny
Ok I will do so looking for them here in Aussie flatjack9
Old 09-25-2022, 08:49 AM   #7
Granny
Flatjack9
I found a set of 0.060 over piston here in downunder
Thanks all for you input
Granny
