Old 09-02-2022, 08:42 PM   #41
Jack E/NJ
Jack E/NJ's Avatar
Default Re: Synthetic Oil?
>>>Any thoughts on a reasonable torque value to prevent weepage AND protect thread integrity?>>>
Snug. Not tight. Weepage is fine with me. Drippage, not so much. 8^)
Old 09-03-2022, 06:24 AM   #42
Jacques1960
Jacques1960's Avatar
Rotella and MMO mix
No job’s done ‘til it’s all done
Jacques1960 is offline   Reply With Quote
Old 09-03-2022, 10:32 AM   #43
RalphInCA
RalphInCA's Avatar
Originally Posted by ford38v8 View Post
I personally think the reports of leaks or no leaks are personal perception and specific to the observed engine. I don't think anyone can point to a scientific study of the question, unless sponsored by an oil company with sales at stake.
This is pretty much true.
There are independent studies that prove differences, but the differences are very slight.
RalphInCA is offline   Reply With Quote
Old 09-04-2022, 09:59 PM   #44
Karl
Karl's Avatar
Hmm -Apparently according to Einstein Gravitational forces are an illusion. Any force we experience is just a consequence of us travelling through space/time -I need to get out more !!
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me.
Karl is offline   Reply With Quote
Old 09-06-2022, 01:43 PM   #45
joe 1950
joe 1950's Avatar
Ah remember the good old days at Western Auto and don’t forget JC Whitney good quality products and reasonable prices well at least Western Auto
joe 1950 is offline   Reply With Quote
Old 09-06-2022, 02:00 PM   #46
tubman
tubman's Avatar
Up until about 10 years ago, I ordered rebuilt carburetors from J.C. Whitney. I wanted to get the original Quadrajet on my '68 Corvette redone, so I ordered a direct replacement for $179.95, no exchange. It worked great out of the box. I did the same thing with the original carb on my '70 el Camino. I think that one was $129.95, no exchange, and I sold it on eBay a few months later for $200.
Old 09-06-2022, 02:08 PM   #47
Robert/Texas
Robert/Texas's Avatar
Joe, Some of the good old days are still here. I bought my 1992 Wizard/Western Auto lawn tractor used in 1994 and we still mow our lawn with it.
Robert/Texas is offline   Reply With Quote
Old 10-24-2022, 12:20 AM   #48
SoCalCoupe
SoCalCoupe's Avatar
Did the deed this weekend, changed the oil and put in 5w-40 Mobil-One European Formula oil. Not totally sure what European Formula means, best I can tell is different additives for extended oil change intervals. But, like RalphInCA said, everything today is so much better than what was available in the 1940's it shouldn't be a worry. Didn't sound poisonous to cast iron blocks.
Bought a new drain plug gasket only to find that it was about 3x the diameter of my drain plug. Must not be a stock oil pan. It has a much smaller diameter plug, maybe 5/8", but with plenty of threads in the pan, maybe at least 1/2". Since my new gasket wouldn't work, thought I'd make my own with a roll of Felpro gasket material.
Well, turns out there was a copper gasket on the drain plug that WAS NOT coming off. It turned, but the diameter was so small I couldn't engage it on the threads to turn it off. Gave up but did my best to clean it up and remove contamination along with contamination of the hole in the pan. Two gaskets are usually worse than one gasket.
Totally agree that ""Weepage is fine with me. Drippage, not so much." "Snug. Not tight" drives me crazy. I THINK that's what I did; I hope so. After 24 hours no drippage or weepage.
Been a long time but when I took my nearly new 1989 vehicle to a shop for an oil change three decades ago, there was A LOT of drippage. A lot of shouting ensued but they finally had to admit defeat and replace the oil pan. Snug, not tight didn't work so well for them.
Wasn't so lucky with another bolt in another part of the car. Have to buy another helicoil set this week, my second this year. Argghh!
SoCalCoupe is offline   Reply With Quote
Old 10-24-2022, 06:22 AM   #49
lotsagas4u
The Valvoline VR-1 is great break-in oil, as it contains a good amount of zinc, which is needed for flat tappet cams. But it does not contain much detergent, so sludge build up could be a concern if you expect to run the engine for 50,000 miles,
There are two versions of this oil, one in black container, low detergent, silver container, normal detergent, both high in zinc.
lotsagas4u is offline   Reply With Quote
Old 10-24-2022, 11:46 AM   #50
ct1932ford
ct1932ford's Avatar
VR-1 20/50 is all I run. I change the oil as soon as it looks dirty.
A man should do what he thinks best! "The Duke"
ct1932ford is offline   Reply With Quote
Old 10-24-2022, 01:36 PM   #51
Tim Ayers
Same here. If you look around, sometimes you can find great deals like $25 a case. It's been a while since I've found a block buster deal like that, but last time I did, I loaded up.
Old 10-24-2022, 03:46 PM   #52
solidaxle
solidaxle's Avatar
To expand on your statement.
The black container is synthetic as stated on the label. The gray container does not mention anywhere that it is synthetic. It states for racing and classic cars "Specially designed for push-rod & flat- tappet engines".
solidaxle is offline   Reply With Quote
