Old 09-01-2022, 09:20 PM   #5
40cpe
40cpe's Avatar
Default Re: Overdrive Issues (again)
Originally Posted by jackson View Post
I rewired the entire OD and in most cases over-sized the wire. For instance, coil to fuse on the relay is #10.
If, in fact, your OD is wired like that you might want to consult a wiring diagram. The grounding points in the solenoid are passed through the kickdown switch and connected to the coil. This is a ground to momentarily kill the ignition so the OD can drop out. Power for the relay is from the battery and the voltage to activate the relay is from the ignition switch.
