Old 08-28-2022, 10:37 AM   #5
rotorwrench
rotorwrench's Avatar
Default Re: 51 Merc into 1940 fordor flywheel clutch questiond
The 49 through early 1951 all used the same 1 3/8" 10-spline as the early Ford. Sometime around February of 1951, the change to the 1-inch 10-spline started along with the big cast iron bell housing.
A person needs the pressed steel half bell of the earlier 1949-E51 Mercury cars. The 49-E51 Borg & Beck clutch can be used or a Ford flywheel can be re-drilled for a Long type clutch of either the 9-inch or 10-inch variety for earlt Fords with the 1 3/8" 10-spline.
