Old 08-14-2022, 03:34 PM   #1
1929fordhotrod
Default 1928-29 Ford roadster door bumpers
I just received my door bumper kit A-702610-ES by Vintage Inc.. I figured out some of the installation but I’m curious where the 4 round mushroom shaped bumper go and the 2 L shaped rubber stops go. I screwed 2 of these on the door but can’t figure out where the other 2 go.
File Type: jpg DAF49A81-7A05-4361-9109-39DA446AF36E.jpg (83.9 KB, 52 views)
File Type: jpg AF43B726-0C9F-44F4-870D-DF56E044A51C.jpg (86.4 KB, 45 views)
File Type: jpg 1F37DD1D-C8CF-4C0A-865C-7C9840B2E330.jpg (27.2 KB, 56 views)
1929fordhotrod is offline   Reply With Quote
Old 08-14-2022, 05:08 PM   #2
Bob C
Default Re: 1928-29 Ford roadster door bumpers
Here's were the round ones go.
Old 08-14-2022, 06:55 PM   #3
Randy in ca
Randy in ca's Avatar
The reproduction round ones are often too thick and need to be shaved down some.
Randy in ca is offline   Reply With Quote
Old 08-14-2022, 09:23 PM   #4
ericr
ericr's Avatar
if you look in the Fastener handbook this is truly how the originals were shaped, odd as that looks. But I am sure the originals were natural rubber and more flexible.
It still seems like an odd design. The 28-29 bodies were assembled by Ford but not acually stamped out by Ford. Who knows designed this piece.
ericr is offline   Reply With Quote
Old 08-14-2022, 10:21 PM   #5
1929fordhotrod
I had a feeling that’s where they went but I don’t have any pre-drilled holes. Is it different for a roadster body?
Old 08-15-2022, 01:59 AM   #6
Randy in ca
The other two L-shaped rubber stoppers go on the bottom of the door a couple of inches from the rear. Should be a hole the same as where the one you've shown in the rear edge goes. I've probably got a picture if needed.
As for the missing holes for the round one to go into the cowl post, not all posts had them. They were absent on both my 1928 Roadster and another cowl post assembly I have (definitely original as pictured below).
File Type: jpg 1928-29 Ford Roadster - Cowl Post without rubber.jpg (53.0 KB, 101 views)
Old 08-15-2022, 02:47 AM   #7
Ford Acar
Here are the instructions that came with mine. The round headed one needed to be shaved down.
https://www.snydersantiqueauto.com/c...-702610-ES.pdf
Ford Acar is offline   Reply With Quote
Old 08-16-2022, 05:19 PM   #8
Russ/40
Russ/40's Avatar
On the forward jam, the bumper hole is 2 inches below the hole for the bottom screw of the hinge. The other is on the rear jam, 2 inches below the top of the cab rail.
