Old 06-09-2022, 01:04 PM   #1
rockfla
rockfla's Avatar
Default Sun Machine serviced
Any one on here had a Sun machine "updated" and serviced lately to give an idea of what it cost to do???
Thanks
Old 06-09-2022, 01:12 PM   #2
KiWinUS
KiWinUS's Avatar
Default Re: Sun Machine serviced
Robert I have not but had always been told it’s easy to do your self
Old 06-09-2022, 01:50 PM   #3
hotcoupe
hotcoupe's Avatar
I suggest that you take a look at the u-tube video by "Opera", very interesting modifications. Dead nuts accurate.l've posted this info before, no one seemed interested, here's the link to one of his videos, https://youtu.be/W7rXdZVCz1Q
Tom
hotcoupe is offline   Reply With Quote
Old 06-09-2022, 02:47 PM   #4
Ken/Alabama
Ken/Alabama's Avatar
http://paramountd.com/parts.html I got the parts here and did it myself. Not hard to do. Comes with good instructions.
Old 06-09-2022, 02:58 PM   #5
rockfla
rockfla's Avatar
Ken
What all did you get, the LED kit, the resistor kit, belts??? The WHOLE shabang??? I'm trying to figure the economics of what to offer on a machine.
Old 06-09-2022, 03:26 PM   #6
Ken/Alabama
Originally Posted by rockfla View Post
Ken
I bought the degree ring roller rubber kit and the capacitor kit. My strobe light worked fine.
Old 06-09-2022, 03:27 PM   #7
rockfla
rockfla's Avatar
Thanks Ken!!!
Old 06-09-2022, 04:14 PM   #8
35fordtn
35fordtn's Avatar
I'll second Mark at Paramount. You can do the work your self or send it off to him. Personally any machine I have would have the LED kit his wheel roller and the battery delete kit. You can mail the machine to him and he can repair for you or even completely restore it. The Machine I took to the Eastern Meet in the seminar was one he restored.
Old 06-09-2022, 06:14 PM   #9
Don
Don's Avatar
I found a Penske analyzer at Hershey one year and connected it to the sun machine and use that for all my readings as the sun instruments needed a lot of work before I would trust them ,the Penske analyzer gives me dwell ,RPM hi and low ,point res,and a couple other things, really works great and has a high resolution easy to read,,I’ve checked it against my KRW 126 and it’s dead on,,
I use the krw to set the timing on the flatheads dist and use the sun for checking and the advance on distributor,works out good,,
I still use a 6 volt battery ,optima ,and keep it charged when using machine,
My flash is a little dim but at 86 I’m a little weak also!!!
DON P
Don is offline   Reply With Quote
Old 06-09-2022, 06:19 PM   #10
Don
Don's Avatar
Forgot to mention,I did put the capicator kit in mine hopeing it might brighten up the flash,but didn’t help any,,
DON P
Old 06-09-2022, 08:18 PM   #11
Angledrive
Angledrive's Avatar
Same here, easy peasy
Angledrive is offline   Reply With Quote
Old 06-10-2022, 11:37 AM   #12
Automotive Stud
Automotive Stud's Avatar
I picked up a machine fairly cheap at an estate sale, only the motor worked. I bought the capacitor kit and some other odds and ends from Mark and the strobe and everything works now.
Automotive Stud is offline   Reply With Quote
