Old 06-09-2022, 11:19 AM   #1
HalcyonDays
HalcyonDays's Avatar
Default Installing metal valve stems
Is there a trick to installing the metal valve stems on Model A tubes? I am 0 for two. I watched the video on You Tube and it appeared very straight forward. I installed the stems, checked for leaks then manually installed tube and tire on rim. Once installed leak happened between metal stem and tube. I did not apply any sealant as per video. Next step for me is to see if I can find tire shop to install tubes and tires on rim, perhaps they could do it with less stress on stem.
I was curious if anyone else ran into this issue and or if thy applied a little sealant.
Thanks for any suggestions.
HalcyonDays is offline   Reply With Quote
Old 06-09-2022, 01:23 PM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: Installing metal valve stems
Do a search here, there is detailed instructions. I'd probably use a sealant, Indiand Head. JMO
Paul in CT
Old 06-09-2022, 01:31 PM   #3
Mike Peters
Mike Peters's Avatar
http://www.sheepisland.com/cars/tech/metal_stems/
Nice pictorial on installing stems. I've installed some metal stems and found that to avoid leaks, you need to tighten that bridge washer as tight as you can without stripping the threads on the valve stem or bridge washer nut.
Mike Peters is offline   Reply With Quote
Old 07-27-2023, 01:22 PM   #4
mhsprecher
mhsprecher's Avatar
I followed this to a T, but two of the tubes developed tears when I was spreading the hole with needle nose pliers to install the metal stems. An expensive mistake, so be careful. These were with the Coker supplied tubes for the American Classic radial tires. Three went in fine, but two, not so good. :-(
1910 Model T Touring
1924 Model T Coupe
1928 Model A Roadster
1930 Model A Town Sedan
1939 Deluxe Fordor
1945 pickup
1951 Custom convertible
mhsprecher is offline   Reply With Quote
Old 07-27-2023, 01:43 PM   #5
J Franklin
J Franklin's Avatar
Are you using some lubricant to ease installation? You shouldn't need any sealant as the rubber should make it airtight if the nut is drawn tight.
Old 07-27-2023, 02:33 PM   #6
jwilliams81
jwilliams81's Avatar
I'll be tackling this in a day or so for the first time since the metal steam 19" tubes are no longer available. Thanks for posting, I will be following the same steps as shown in the link from Mike Peters... hoping for a good outcome. I will post back
1931 Murray Town Sedan. Black body with Apple Green pin stripe.
1923 Model T Touring with electric start. Low radiator
Cincinnati, Ohio
jwilliams81 is offline   Reply With Quote
Old 07-27-2023, 03:13 PM   #7
ryanheacox
ryanheacox's Avatar
I did 5 tubes back in January. I bought one extra but didn't end up needing it. I followed that guide but used a regular pair of needle nose pliers with a nice radius on the outside that wouldn't bite into the tube. It's now been 7 months, 1200 miles and no leaks.
Old 07-27-2023, 04:49 PM   #8
Kurt in NJ
Kurt in NJ's Avatar
i have just done some, cleaned the anti stick powder off around the hole inside the tube, a dab of dish soap and just pushed the stem in sideways, nothing to expand the hole, no glue
Old 07-27-2023, 08:35 PM   #9
1crosscut
1crosscut's Avatar
If you noticed the air escaping between the valve stem and wheel right after filling that is normal (but it can alarm you) as the air trapped between the tube and the tire needs to escape. Let them sit for a while and recheck the air pressure. You may not have a problem.
Also I don't put the valve stems in right away. I fill them at least twice and immediately let the air out to allow the tubes to untwist and settle in before installing the valve stem for the final fill.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 07-29-2023, 09:08 AM   #10
Bob Bidonde
Bob Bidonde's Avatar
My record is one leaker and 4 successes in my latest conversion to metal valve stems. I have learned the hard way that there must be 1/16" to 1/8" of the rubber valve stem left standing to make a seal.
Bob Bidonde
Old 07-29-2023, 11:49 AM   #11
Richard in Anaheim CA
Richard in Anaheim CA's Avatar
I have installed several sets and do not use tools to insert the stems.
I dip the stems in soapy water and just push them into the tube with my thumbs, edgewise of course. I haven't used any sealant. A second set of hands is helpful too.
Richard
Anaheim CA
Richard in Anaheim CA is offline   Reply With Quote
Old 07-29-2023, 01:11 PM   #12
HalcyonDays
To follow up on my original post. It turned out the metal valve stems I had installed were not the cause of the leaking tube. While installing the tire on the rim I inadvertently ripped the tube. The rip was not close to the valve stem but when the tire was inflated the air was coming out around the valve stem. The big lesson for me was how to install tires on rims using a plastic bag and zip ties, much easier than what I had been doing. Metal valve stems now have been installed on new tubes and tire on rims no leaks.
Old 07-30-2023, 10:27 AM   #13
rackops
rackops's Avatar
Exact same thing happened to me on two of my tubes. Very frustrating, for sure!
As far as installing the metal stems, I personally found that dish soap and elbow grease were the best way to get the stems in the holes. That was after I tore two tubes while installing the stems.
Member, MARC
Current owner, 1928 RHD Australian-built Phaeton CA4752 "Felicity"
Former owner, 1931 Victoria, 1929 Phaeton, 1929 Fordor
rackops is offline   Reply With Quote
