Old 05-30-2022, 06:32 PM   #1
russcc
Default 12V Resistor type coil.
Running the 59L on 12 volts. I prefer not to fool with resistors, and have run it with a resistor type coil for years, and it runs great.
I have not bought a new coil for years. Which resistor type coil is a quality product, preferably made in the USA ? Thank you.
Old 05-30-2022, 07:13 PM   #2
51504bat
51504bat's Avatar
Default Re: 12V Resistor type coil.
I use a 12 volt Bosch internal resistor Blue Coil. Part number 012. Its what Buba recommended for the Chevy distributor conversion on my 8ba. No issues for 5 years or so.
Old 05-30-2022, 07:28 PM   #3
JayChicago
JayChicago's Avatar
As said above, I have read several knowledgeable ignition experts recommend the Bosch Blue coil. It's 3 ohm, so appropriate for 12 volt, no resistor.
Probably not made in USA. Bosch is a German company. Don't know if any coil is actually manufactured in the USA. Even Fomoco or Delco or Mopar electronic products are probably made elsewhere.
BTW, don't be tempted to go with a high performance, race engine coil. They can over-power the flathead's distributor and spark plug leads, cause shorting somewhere before reaching the spark plug.
Old 05-30-2022, 08:08 PM   #4
Flathead Fever
Flathead Fever's Avatar
I remember those Bosch blue coils being the hot ticket on the sand rails and Baja bugs in the 1970s. They took a pounding and never failed. It still seems to be everybody's favorite. It would be nice to think there is still someone making a quality part.
Old 05-30-2022, 10:00 PM   #5
GB SISSON
GB SISSON's Avatar
I ordered one last week on ebay. The posting showed our old favorite with that nice thick coat of blue paint. Mine came in a bare aluminum case with a blue bosch stick on label. I was going to send it back but did research and everything seemed to say it superceeds the one we know. It is made in Brazil, which to bosch coil nuts online means it is a good one. Let's find a company to order from that still stocks the tried and true. Not a big deal probably, just a heads up.
Old 05-30-2022, 10:28 PM   #6
Tinker
Tinker's Avatar
Being bosch should be from Germany or the big check. Think they have been made in South America for quite a while.
I have one in a box when they were selling low yrs ago just encase. I'm still 6volt but who knows.
Old 05-31-2022, 08:51 AM   #7
Automotive Stud
Automotive Stud's Avatar
I've been running a Bosch blue coil also, my only issue is hard starting when hot. I actually am switching to a Mallory coil with an external ballast resistor so I can bypass the ballast resistor on startup like many factory cars used in the '60's. We'll see if that helps.
Automotive Stud is offline   Reply With Quote
Old 05-31-2022, 10:55 AM   #8
jailhousebob
I have had 2 bosch blue coils go bad and leave me on the side of the road.Both coils were less than 2 monthes old.After the 2nd one i bought an accel and hooked up the external resistor again.That one has lasted 4 years w/o a problem. I bought the bosch after hearing everybody say good things about them but they didn't work out for me.Bob
jailhousebob is offline   Reply With Quote
Old 05-31-2022, 12:38 PM   #9
flatjack9
flatjack9's Avatar
Never had a problem with that Bosch coil. I use them in most of my builds.
Old 06-01-2022, 06:16 AM   #10
OldCadillac
In my opinion Bosch has now not the same quality like in the past. But this depends on it where the part was manufactured. I already had a bad new blue coil which was broken after very short time. Normally Bosch was the original equipment in all the old Mercedes. But now when I need new spark plugs for Mercedes, I always buy NGK plugs. They run mostly much better as the Bosch if they where manufactured in India or Russia. I don’t know what ignition parts Bosch still produce here in Germany. Or if they do…
I have no experience with NGK coils but perhaps they could be an alternative?
Tom
OldCadillac is offline   Reply With Quote
Old 06-01-2022, 02:38 PM   #11
wga
wga's Avatar
Russ - bought mine 4 years ago and still running fine with either distributor I've used -
Mallory dual point and a Bubba GM conversion.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Henry Ford designed the flathead without the aid of a computer.
wga is offline   Reply With Quote
Old 06-01-2022, 03:23 PM   #12
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Bosch 00012 amazon .com
I have never never seen a defective Bosch blue ignition coil and suggest using the Bosch coil...........
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
