Old 03-31-2022, 02:03 PM   #1
maph2
Default Mating a model A engine to T pan and trans
I understand its possible to fit a Model A block/engine to a Model T pan and transmission. Is there any more info out there on what needs to be considered?
maph2 is offline   Reply With Quote
Old 03-31-2022, 02:17 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Mating a model A engine to T pan and trans
Why would you even want to do this???? Anything is possible if you have enough money and willpower.
Old 03-31-2022, 04:30 PM   #3
maph2
A) I have a T speedster project/gow/rod whatever
B) I'm not in 'murica so T engines aren't that common
C) my T engine is in bits
D) I have complete running A engine
Any "actual" info would be helpful, not just a load of negatives please.
Old 03-31-2022, 05:06 PM   #4
Y-Blockhead
Y-Blockhead's Avatar
Is there any reason you can not use the Model A transmission? It sure would simplify your life.
Old 03-31-2022, 05:28 PM   #5
29spcoupe
29spcoupe's Avatar
A friend of mine mated a Model A block to a Model T pan and tranny. He wanted the 40 hp engine, but still wanted it to drive like a Model T. It was truly a work of art. He had, in effect, 40 hp Model T. John
29spcoupe is offline   Reply With Quote
Old 03-31-2022, 06:00 PM   #6
J Franklin
J Franklin's Avatar
When you get this swap on, take a lot of photos. I think it would be very interesting to share.
Old 03-31-2022, 06:03 PM   #7
J Franklin
J Franklin's Avatar
I agree since the T transmission and bands add a lot of weight and weakness.
Old 04-01-2022, 02:08 AM   #8
maph2
T braking is mostly via the transmission so i want to keep the T transmission. No front brakes.
Old 04-01-2022, 02:13 AM   #9
maph2
my A engine is a 2 litre small bore version but T tranmissions happily take hopped up engine power eg rajo ohv conversions
Old 04-01-2022, 02:26 PM   #10
rotorwrench
rotorwrench's Avatar
A lot of folks used an over under box in the final drive or a Ruckstell axle. A person doesn't get much with the T planetary two speed.
The model A engine has a lot more potential than the T engine and is heavier. The T frame is so flexible it bends if you only lift one corner. Personally, I like to be able to stop as least as well as go. The late 26 & 27 Ts were the best ones to speedsterize. If I was going model A then I'd stay with later frame and equipment even if I had to fabricate it. The T stuff was never made for high speeds. The T was the end of the horseless carriage era.
Old 04-28-2022, 08:44 PM   #11
FRANK PKNY
FRANK PKNY's Avatar
John the guy was Gus Lovey from Kingston NY
A family member inherited the car after his death. I wonder where the car is today?
FRANK PKNY is offline   Reply With Quote
Old 04-29-2022, 06:17 AM   #12
29spcoupe
29spcoupe's Avatar
Frank, the last I heard, it was with his grandson in Kansas.
Old 04-29-2022, 08:17 AM   #13
jimTN
It would be a lot simpler to get a good HC head and hot cam and build the t block.
Old 04-29-2022, 09:55 AM   #14
rotorwrench
Ford made over 15-million Ts so quite a few made it to other parts of the world. I'd start looking for T folks in your neck of the woods. You may be surprised about what's out there.
Old 04-29-2022, 10:56 AM   #15
JoeBauer
Yup. CID is basically the same with T and A blocks, and they both are L head. HC head and Stipe cam help a lot, but get more power by using an A intake and exhaust manifold, then an A carburetor which is far superior to the T carburetor. And a distributor fires much more accurately than buzz coils.
JoeBauer is offline   Reply With Quote
Old 04-29-2022, 05:52 PM   #16
39portlander
39portlander's Avatar
Funny...I fail to see the load of negatives.
Exactly, why. Keep the running A, there are sooooooo many model A's out there with non running gear to be had for cheap and putt'er in.
Want a T, buy a T. Unfortunately the price of these buggers has doubled over the last few years. Good luck and lettuce know how you make out.
39portlander is offline   Reply With Quote
Old 04-29-2022, 07:55 PM   #17
redmodelt
redmodelt's Avatar
Ah heck just drop in the V8 60!
Old 04-29-2022, 08:42 PM   #18
J Franklin
J Franklin's Avatar
That would be fun! My Dad told me a story about as a young man he was a reporter for the local news and had a ride in a stock looking model T. The owner was a racer and had put an offy engine in the car and was teasing a few large car owners into racing.
Old 04-29-2022, 09:44 PM   #19
29spcoupe
29spcoupe's Avatar
I was on a tour with a guy from NJ who had a '27 T roadster with a V8 60 in it.
That thing could move!
Old 09-20-2022, 06:07 PM   #20
Quiggs88
My name is James Quigley and my great grandfather was Gus Lovy. His 1924 Model T is still in the family. It currently is and has been in Oklahoma since he passed away I think about 20 years ago now. I actually talked to Donald Lovy who currently has it and we agreed to bring it back to New York. We plan on getting it here for the 2023 Rhinebeck car show.
Quiggs88 is offline   Reply With Quote
