Old 04-28-2022, 03:46 AM   #1
ford nut
ford nut's Avatar
Default 1936 coupe 1/4 window rubber seals
i bought a pair of 1/4 window seals from cw moss. not real happy with them,
when i removed the old glass the gaskets came off in bits & pieces and i noticed a small bead on the outside top edge. the new ones are missing this detail.
any better ones out there? thanks, kurt.
ford nut is offline   Reply With Quote
Old 04-28-2022, 12:59 PM   #2
deuce lover
deuce lover's Avatar
Default Re: 1936 coupe 1/4 window rubber seals
Not really.Drake ones I bought in 08 didn't have that bead you mentioned.Just a plain U-shaped rubber that you cut and fit.Why would it be at just the top and not all the way around ? Maybe your were squished over the years?
Old 04-28-2022, 03:00 PM   #3
TJ
TJ's Avatar
I suspect that bead was caused by the pressure on the gasket up against the body and when the seal dried out it kept that shape. I have bought those seals from a variety of vendors and manufacturers and never saw a bead on those seals.
TJ is online now   Reply With Quote
Old 04-28-2022, 04:43 PM   #4
ford nut
ford nut's Avatar
no, the bead was molded into it. the bead goes all the way around, thats why i said it's on the top edge. if you did a cut away, the bead is on the top of the U shape. i have a piece saved, if it didn't get tossed, i'll show.
Old 05-12-2022, 10:05 PM   #5
325w
In about 1993 I bought 1/4 window rubbers for the 5w. Had the bump out. Redid the windows while back and no bump out.
325w is offline   Reply With Quote
Old 05-12-2022, 10:21 PM   #6
ford nut
ford nut's Avatar
i could never find that broken piece i had that showed it. thanks for your reply.
Old 12-11-2024, 08:55 PM   #7
flatfoota37
Where May I purchase 1936 Ford 4 dr sedan rear 1/4 window seals; swing out type? Are non swing out rubber seals the same?
flatfoota37 is offline   Reply With Quote
Old 12-12-2024, 10:22 AM   #8
TJ
TJ's Avatar
The swing out seals are different. If none of the parts dealers have them you might try Metro Molded Products.
