Old 04-26-2022, 02:16 PM   #1
Mart
Mart's Avatar
Default Pendine Prep 11. Top end tidy up. Cylinder heads milled and fitted.
Hello and welcome to Mart's Garage. In this week's video I show setting up the heads for milling, taking 30 thou off them and getting them installed. Thanks to Casey at @Crazy Casey’s Customs for the bolt painting tip. It certainly improves the looks.
I hope you find it interesting, it's another step in the right direction in getting the car ready for racing on the beach at Pendine.
https://youtu.be/kCGTI7HUb4U
Old 04-27-2022, 09:58 AM   #2
corvette8n
corvette8n's Avatar
Default Re: Pendine Prep 11. Top end tidy up. Cylinder heads milled and fitted.
Mart thanks for the video, I sent you an off topic pm a few weeks ago, hopefully it didn’t get lost.
Old 04-27-2022, 11:44 AM   #3
Mart
Mart's Avatar
Thanks Vette. It didn't get lost, I just didn't know how to answer! Reply sent now.
Old 04-27-2022, 11:52 AM   #4
mfirth
Nice job Mart. Good looking isn't it? Bet she'll run GR8.
mfirth is offline   Reply With Quote
Old 04-28-2022, 11:49 AM   #5
Russ/40
Russ/40's Avatar
Mart, you make no clarifying comment in your video regarding whether or not you did any measuring for quench or valve to head clearances. Could you comment a bit on what assumptions were made, and why? I think it to be important for those that are not starting with new heads, but used heads.
Old 04-28-2022, 03:38 PM   #6
Mart
Mart's Avatar
Hello Russ, you are right. I did mention it but only briefly in passing. I did film measuring the clearances but I had to skip some steps in the interest of watchable video length. I faffed around with the Offy heads before settling on the Edelbrocks so when it came to putting a video out I just stuck with the Edelbrocks.
I measured all the piston crown to head dome clearances with the Edelbrock and Offenhauser heads. I used aluminium foil balls. The clearances came out at 80 thou or a little over. I checked over the valves and it was greater than 80 thou. Can't remember exactly without checking the raw footage. I remember 40 thou is quoted as optimum but didn't feel brave enough to shoot straight for that so took 30 thou off to achieve a theoretical squish of 50 thou. I imagine it might be tighter in reality after head gasket torqueing.
I'm not an engine builder and just go with what feels right at the time. If I make a mistake I am prepared to fix it.
Hope this helps.
Mart.
