Old 04-04-2022, 08:46 AM   #1
AnthonyG
AnthonyG's Avatar
Default 1940 PU upper radiator mounting bracket
Hi all, are these the correct upper mounting brackets for a 1940 PU & can anyone show a picture of upper mounts on a truck? https://www.dennis-carpenter.com/tru...SABEgJjD_D_BwE
Nomad
AnthonyG is offline   Reply With Quote
Old 04-04-2022, 09:06 AM   #2
oldskool
oldskool's Avatar
Default Re: 1940 PU upper radiator mounting bracket
yep thems the ones
oldskool is offline   Reply With Quote
Old 04-05-2022, 07:40 AM   #3
pistonbroke
The same ones only mine are rustier. Tim
Old 04-06-2022, 08:57 AM   #4
AnthonyG
AnthonyG's Avatar
Mine has an odd configuration & the radiator doesn’t look stock. Can one of you take a pic of the mounting orientation of those brackets on the truck? Here’s a couple pics I think shows what Mine looks like. Pics were of engine but shows the home made non stock metal strap hold down radiator brackets.
File Type: jpg AE52E851-8751-4B03-87A3-FAEC5291314C.jpg (47.2 KB, 23 views)
File Type: jpg 922B2FD2-A467-4251-9F17-9A4FE48F4539.jpg (49.5 KB, 24 views)
Nomad
Old 04-06-2022, 10:17 AM   #5
Cecil/WV
Cecil/WV's Avatar
That engine doesn't look anything like mine!
Cecil/WV is offline   Reply With Quote
Old 04-06-2022, 10:30 AM   #6
TJ
TJ's Avatar
The brackets mount to the side of the radiator and bolt to the inner fender panels. look for slots in the sides of the radiator.
Old 04-06-2022, 10:42 AM   #7
AnthonyG
AnthonyG's Avatar
[QUOTE=Cecil/WV;2119268]That engine doesn't look anything like mine![
Lol, kinda thought that engine would draw a comment I’m not at the truck’s location or I would’ve taken a more localized pic avoiding engine if I was there .
It was the only pics I had showing the existing radiator & support brackets. I want to put a radiator made for increased HP which are easily bought & wanted to see how the stock Upper mounts look. The radiators I’m looking at appear to have mounting holes on sides to accommodate the stock brackets.
Nomad
