I've watched all of the U-Tube videos and read/heard all of the sales pitches of various products and am understandably thoroughly confused, which at my age ain't unusual. What have YOU used and with what short/long term results?
#2 | |
Counselor....Sometimes, you have to be ready to accept the fact that you just CAN'T make chicken salad out of chicken dookie! DD . |
My Daddy always told me "Can't never did anything". He was a wise man. (Picture a laughing emoji here)
Super Moderator
Soaking in automatic transmission fluid works occasionally.
Back in the time when we used to use gasoline as a lubricant to sand lacquer
color coats prior to buffing and polishing, rubber squeegees were used as part of the process. If you left a squeegee in a bucket of gas overnight, the next day the squeegee was like a limp noodle.
#6 | |
#7 | |
as I recall remained softer than they originally were.
#8 | |
Picture a frowning guy who CAN'T post pictures, here. DD |
I have just been trying to follow your lengthy dissertation to me about posting pictures, DD. 'Nuff said.
Life is like a roll of toilet paper. The closer to the end, the faster it goes. It is better to be seen, than viewed. "We sleep safe in our beds because rough men stand ready in the night to visit violence on those who would do us harm". Last edited by Lawson Cox; 03-28-2022 at 08:26 PM. |
It must be remembered that any and all of the products mentioned in this thread are solvents, and as such, will break down the composition of rubber as manufactured. In that less than stable condition, rubber becomes soft and gummy. Some solvents are better than others for use with rubber. The rubber industry uses toluene, which freshens up cured rubber that is to be rebonded, such as tires with recaps. If to be bonded, heat and pressure is used. If used only to freshen the surface, the end result will initially appear and feel as new, but is in fact a degradation of the original surface.
Alan |
Some good tips here > https://homeguides.sfgate.com/chemic...-13414995.html
What Alan said in post #10.
Common bleach (sodium hypochlorite) works sometimes. We used to soak our qualifying tires for the midget in it before it was illegal. |
#13 |
We used to use brake fluid to make tires blacker, not sure what it does to rubber though
#14 |
have you ever put a brake cylinder cup in a gasoline bucket. next day as big as a jar cover
#15 |
Best analogy yet. LOL
IN GOD WE TRUST - SEMPER FIDELIS John
#16 |
Just the reverse:
If you have something soft, how do you get it hard. ![]() John |
#17 |
Lawson
Make an accurate sketch of what you need to show. Base od, Height, od 1/4 up from base, od 1/2 up from base, od 2/3 up from base, id and height of hole you need for mounting. Post, pm, or email. I will make a 3D model and print in hard plastic. You should be able to paint it flat black and epoxy onto your pump and make it look as good as new yet "for display purposes only". |
#18 |
I've heard that Model A guys will soak NOS radiator hoses in boiling water to soften them to be able to install them. Doesn't mean they won't leak, though.
#19 | |
#20 |
Or picture a guy with a soft noodle in one hand and a piece of hard rubber in the other hand, who still can't post a picture
| Thread Tools | |
| Display Modes | |
