Old 02-04-2022, 01:55 AM   #41
V8COOPMAN
V8COOPMAN's Avatar
Default Re: 1939’ Deluxe 2DR Sedan
Originally Posted by ssffnomad View Post
Hi Guys. Dreaming about a OD trans.
) Does a 39’ Coupe & a 39’ Sedan have the same floor pan in front of rear axle ?
) I measured 17” from the rear of Torque Tube forward to where the Floor steps down. I tried looking up Mitchell specs. Anyone know how far forward from the Torque Tube a Mitchell gear box is ?
Thanks, Stretch
This is a Mitchell installed in a '47 Ford, I believe. You can see the modifications to the floor that were necessary to keep unit from hitting the floor while traversing bumps. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 02-04-2022, 08:28 AM   #42
ssffnomad
ssffnomad's Avatar
Coop. Yes pic I posted was 6V non turn signal socket.
I did source offset pin 12V Bayonet Bulb Sockets for #1157 Bulbs.
T/Y. Stretch
ssffnomad is offline   Reply With Quote
Old 02-04-2022, 08:36 AM   #43
ssffnomad
ssffnomad's Avatar
Coop, this s a pic of the front of a Mitchell OD, in a 39’ Coupe. There is 3/4” clearance from front edge to step in floor board. No floor modification.
It is coming out this next week. I am putting it in our 39’ Sedan . Hopefully it clears floor ? We will know soon.
T/Y, Stretch
Old 02-04-2022, 10:05 PM   #44
ssffnomad
ssffnomad's Avatar
907DF2BA-244D-459A-B578-5C2F9B49C2E1.jpgI was trying to feel the access cover through the glued on carpet. Previous owners did not have a screw in cover hole. I was unable to locate.
Friend sent me measurements off his 40’ Coupe.
Cut carpet nice and clean . Now can hook up new harness wires.
T/Y. Stretch
Old 02-17-2022, 09:46 PM   #45
ssffnomad
ssffnomad's Avatar
Well 2021 Christmas was , well let’s say , so so . . .
Today was a day to go pick up a nice gift day .
Old 02-18-2022, 08:24 AM   #46
flathead48
Very sharp automobile. Happy motoring
flathead48 is offline   Reply With Quote
Old 02-22-2022, 09:05 AM   #47
ssffnomad
ssffnomad's Avatar
Good Morning. So I potentially have the opportunity to go look at some 39’ passenger car parts. Thinking I should get a couple extra wheels and brake drums.
So, today’s question is, is it true to take and measure the drum wear with a steel 12” ruler ?
Stretch
Old 02-22-2022, 10:18 AM   #48
V8COOPMAN
V8COOPMAN's Avatar
Oops!
T5 W/TORQUE TUBE
Old 02-22-2022, 10:24 AM   #49
V8COOPMAN
V8COOPMAN's Avatar
Stretch
You can get sorta-close with a steel rule, but that is no way to accurately measure the INSIDE DIAMETER of a brake drum. This tool BELOW by "Gearwrench" is one of the less-costly tools for measuring drums. I just gave-away an older one that has a dial on it that accurately measures in THOUSANDTHS of an inch (SECOND pic BELOW).
For instance, the LIMIT on OVERSIZE for old Ford drums is 12.060" (max) on a stock drum which is 12.000" to start with. In other words, ONLY 1/16" (approx) difference to be measuring wityh a ruler. DD
T5 W/TORQUE TUBE
Old 02-22-2022, 11:32 AM   #50
SoCalCoupe
SoCalCoupe's Avatar
Attachment 484527
Attachment 484528
SWEET!!!
Now I know what I want for Christmas 2022.
Really like the look of your car! Had overlooked this thread until this morning. Just bought my own FH last fall and been thinking about how to hotrod it. Period look, dual carbs, OD, nice rake.
Before I hit the interstate though, I think I'll also add front disc brakes. That 3-second following rule learned in 1970's high school driver's ed has gone the way of the dodo bird. Now it's just a sign of weakness that means two more cars can squeeze in front of you. People assume everyone has 4-piston big brakes and can go from 70 to zero in 100'.
SoCalCoupe is offline   Reply With Quote
Old 02-22-2022, 02:34 PM   #51
ssffnomad
ssffnomad's Avatar
Thank You Gentlemen
Stretch
Old 02-22-2022, 10:40 PM   #52
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by SoCalCoupe View Post
SWEET!!!
You don't need discs, and you quite possibly don't realize everything ELSE that must be considered when installing disc brakes, other than the discs and calipers. Put some Boling Brothers' Bendix brakes on that thing and you have more brakes than you'll ever need with those SKINNY TIRES. Even when you can lock-up the tires, the size of the contact patch on the tires (determined by tire size) is going to determine how quickly you can stop. Once you've locked 'em up with decent drums & shoes, disks won't make you stop one inch sooner! Who could'a guessed? DD
T5 W/TORQUE TUBE
Old 03-02-2022, 11:51 AM   #53
V8COOPMAN
V8COOPMAN's Avatar
Stretch
Another device for measuring brake drum diameter. DD
T5 W/TORQUE TUBE
Old 03-02-2022, 01:20 PM   #54
ssffnomad
ssffnomad's Avatar
Coop, thanks. Thought I had a lead on some 39’ wide 5 drums within driving distance.
No so.
Stretch
Old 03-03-2022, 10:14 PM   #55
Farley's34
Nice looking 39 Tudor. Did you buy the O/D unit from Joe W. ?
Farley's34 is offline   Reply With Quote
Old 03-03-2022, 10:28 PM   #56
ssffnomad
ssffnomad's Avatar
No Sir
Old 03-17-2022, 08:40 PM   #57
ssffnomad
ssffnomad's Avatar
Happy St. Pats day .
And a productive day it was.
12V conversion / cloth harness project under control.
So , it was time to dive into drivetrain. Plan is to switch out 39’ 3spd & Throw Out Bearing while installing 36% Mitchell OverDrive . Working by myself on 4 post lift, got the floor boards up. Found out I had to remove the Ford hot water heater to get the metal floor board out. Took tires and wheels off . Lowered and slid the Spring / Axle back.
Left the Trans in place. Removed the Torque Tube and Shaft. After Neighbor got home we slid the Mitchell unit in . Slid the Spring and Axle back up in place.
This experiment was to put my crazy mind at ease. That the Mitchell gear box would actually clear the step down from trunk to rear seat floorboards. It is close , but we believe we should be ok. Maybe I should of took Steve Mitchell’s advice that clearance would not be a issue. But being this sedan is lowered , always had me wondering.
Will sleep great tonight because it fits . And me a tired Olde boy .
Stretch
Old 03-17-2022, 10:34 PM   #58
ssffnomad
ssffnomad's Avatar
So after dinner, cleaning up tools in the Cab if find this metal ring. Is this part of shift lever parts ?
T/Y
Stretch
Old 03-20-2022, 12:14 PM   #59
ssffnomad
ssffnomad's Avatar
Going back together soon, would really like to know where this metal ring came from ?
T/Y , Stretch
Old 03-20-2022, 02:07 PM   #60
19Fordy
19Fordy's Avatar
nomad:
That snap ring might be this piece: Part #17286
https://www.ebay.com/itm/391742811938
Here's the drive train pictorial with that part number.
http://www.vanpeltsales.com/FH_web/F...nd-32-48-A.jpg
