Old 01-24-2022, 03:36 PM   #1
hotrodA
hotrodA's Avatar
Default windshield crank mechanism ID
I thought that I knew what year this is, but old age.took over. 36 ??
Any thoughts?
Thanks!
hotrodA is offline   Reply With Quote
Old 01-24-2022, 03:50 PM   #2
petehoovie
petehoovie's Avatar
Default Re: windshield crank mechanism ID
Any thoughts?
Thanks!
Old 01-24-2022, 06:48 PM   #3
swedishsteel
The shaft that accepts the turning knob is different than my '36's--mine is splined all the way to the end and the end is threaded for a screw to hold the knob on.
swedishsteel is offline   Reply With Quote
Old 01-24-2022, 07:50 PM   #4
TJ
TJ's Avatar
Looks like a '37.
Old 01-24-2022, 08:30 PM   #5
Zeke3
Zeke3's Avatar
The 37 has two attachments to the windshield rather than a single attachment.
Zeke3 is offline   Reply With Quote
Old 01-24-2022, 09:54 PM   #6
Lawson Cox
Lawson Cox's Avatar
What swedishsteel and Zeke3 said.
Old 01-24-2022, 10:25 PM   #7
1937sedandelivery
ditto for the 37 version
1937sedandelivery is offline   Reply With Quote
Old 01-25-2022, 12:33 AM   #8
petehoovie
petehoovie's Avatar
Old 01-25-2022, 05:36 AM   #9
deuce lover
deuce lover's Avatar
If the shank for the handle is square its 33-34 pass car.35-36 are splined.
Old 01-25-2022, 07:57 AM   #10
Lawson Cox
Lawson Cox's Avatar
Okay. Now that it's opened out, it is a 37.
Old 01-25-2022, 12:59 PM   #11
Brian
Brian's Avatar
I reckon it's out of an English V8 Pilot....very similar to 35-36, but the shaft is longer on account of the Pilot's thicker dashboard.
Old 01-25-2022, 10:48 PM   #12
Clem Clement
Clem Clement's Avatar
38/39 the handle is up right and safer for a child riding in the middle
Old 01-26-2022, 08:03 PM   #13
kustoman
The English ford pilot is the same as a 36, but with an extension, on the winder, from memory it is plain like the photo and can be unscrewed.
kustoman is offline   Reply With Quote
Old 01-26-2022, 10:04 PM   #14
38 coupe
38 coupe's Avatar
The 39 has the upright handle. 38 is like 37, comes horizontally through the dash.
Old 01-27-2022, 01:32 PM   #15
Model51
Model51's Avatar
Attached is an image of the one which came of my late-production 1935 Model 51 truck. I assume it's the same as the Model 50 and 67 pickups. Other than the extended crank handle shaft, it looks very similar.
Hopefully the image is attached.
File Type: jpg Model 51 50 and 67 windshield regulator.jpg (32.6 KB, 17 views)
Model51 is offline   Reply With Quote
Old 01-27-2022, 10:55 PM   #16
hotrodA
hotrodA's Avatar
Thanks, I’ll see if the extension is removable.
Old 01-28-2022, 04:36 PM   #17
hotrodA
hotrodA's Avatar
It is! Screw came right out.
So it appears to be 35-36, or English with the extension. Turns freely after a cleaning and some Gibbs.
You guys are GOOD!
Thanks!
Old 06-14-2022, 09:31 PM   #18
Clem Clement
38 coupe. You are right. MY bad. 38 shaft faces backward. 39 faces up, away from small folks sitting in the middle
