I thought that I knew what year this is, but old age.took over. 36 ??
Any thoughts? Thanks! |
#2 | |
The shaft that accepts the turning knob is different than my '36's--mine is splined all the way to the end and the end is threaded for a screw to hold the knob on.
Looks like a '37.
The 37 has two attachments to the windshield rather than a single attachment.
ditto for the 37 version
If the shank for the handle is square its 33-34 pass car.35-36 are splined.
Okay. Now that it's opened out, it is a 37.
I reckon it's out of an English V8 Pilot....very similar to 35-36, but the shaft is longer on account of the Pilot's thicker dashboard.
38/39 the handle is up right and safer for a child riding in the middle
#13 |
The English ford pilot is the same as a 36, but with an extension, on the winder, from memory it is plain like the photo and can be unscrewed.
#14 |
#15 |
Attached is an image of the one which came of my late-production 1935 Model 51 truck. I assume it's the same as the Model 50 and 67 pickups. Other than the extended crank handle shaft, it looks very similar.
Hopefully the image is attached. |
#16 |
Thanks, I’ll see if the extension is removable.
#17 |
It is! Screw came right out.
So it appears to be 35-36, or English with the extension. Turns freely after a cleaning and some Gibbs. You guys are GOOD! Thanks! Last edited by hotrodA; 01-28-2022 at 05:35 PM. |
#18 |
38 coupe. You are right. MY bad. 38 shaft faces backward. 39 faces up, away from small folks sitting in the middle
| Thread Tools | |
| Display Modes | |
