drive it a 100 miles and check again.
then if it is still low do a leakdown test if you are still worried. How evenly does it pull from low rpm (10 mph) in top gear? |
Just drive it and enjoy it.
Like others, I would drive as is and enjoy it. Summer is just around the corner. Seafoam and MMO are your friends if it has spent a lot of time sitting and has some stuck rings and sticking valves.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
#5 | |
You might check your accel pump and see if it is squirting correctly (do it with the engine not running first!). It can also be timing . . . |
#6 | |
Good thought. |
| Thread Tools | |
| Display Modes | |
