Old 12-20-2021, 07:40 PM   #1
Veeder
Default DISTRIBUTOR GUIDE PINS (Helmet and Crab style)
I've become pretty good at taking off the distributor and reinstalling in but always struggled just a bit getting the bolts started ,gasket in place and cam aliened properly......
I decided to try to make some guide pins out of orange fiberglass rod and cutting each about 3 inches long (think of half a pencil). Buy inserting one in each of the three holes they stuck out nicely allowing good viability to slide the distributor over them and then one at a time remove the pin replace it with the bolt. Making sure the cam is lined up with the distributor properly.
Just thought I would pass it along it really helped.
Veeder is offline   Reply With Quote
Old 12-20-2021, 08:20 PM   #2
paul2748
paul2748's Avatar
Default Re: DISTRIBUTOR GUIDE PINS (Helmet and Crab style)
Is it possible to use studs instead of bolts. Solves the whole problem
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 12-20-2021, 08:21 PM   #3
flatjack9
flatjack9's Avatar
I cut the heads off of several bolts to use as guide pins. Makes the job so much easier.
Old 12-20-2021, 08:22 PM   #4
flatjack9
flatjack9's Avatar
Would work just fine.
Old 12-20-2021, 08:23 PM   #5
ford38v8
ford38v8's Avatar
Two studs. Three is overkill.
Alan
Old 12-20-2021, 11:57 PM   #6
JM 35 Sedan
JM 35 Sedan's Avatar
I also made mounting pins by cutting the heads off of bolts that have the correct size threads. I use two mounting pins to align my '35 distributor on the front of engine. Then slowly turn the rotor by hand untill the off center keyed distributor shaft aligns with the slot on front of cam. Then bolt the distributor in place after removing each pin.
John
Old 12-21-2021, 07:52 AM   #7
rockfla
rockfla's Avatar
Here are the ones I came up with. The early cars, some do not have the luxury of space between the motor and the radiator SO mine as somewhat shorter. I have since knurled the end so you can insert and remove with your fingers 90% of the time, IF they get a little difficult then a short flat tip screw driver works perfectly. JM35Sedan I am in the same exact boat/procedure as you!!!!
Old 12-21-2021, 08:12 AM   #8
Veeder
I'm going to make a set just like those maybe add a taper at the end.
Thanks!!!
Old 12-21-2021, 09:43 AM   #9
rockfla
rockfla's Avatar
Thanks!!!
NOTE......I cut the threaded part down shorter too. You only need just a few threads for what they are intended for SO they are a lot easier to screw in and out!!!!
Old 12-21-2021, 10:50 AM   #10
GB SISSON
GB SISSON's Avatar
I have struggled with mounting the distributer as well. This is a really great idea. Thanks for sharing it!
GB SISSON is online now   Reply With Quote
Old 12-21-2021, 01:14 PM   #11
V8COOPMAN
V8COOPMAN's Avatar
A 'fastener' guy like yourself ought to have a PART Number for those! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 12-21-2021, 01:16 PM   #12
rockfla
rockfla's Avatar
Lol
I thought about making several sets....I have made a few for a few people!!!! IF someone needs I can make some for them!!! The hardest part for me is cutting the slot as I have to have my machinist friend do it, I don;t have my mill YET!!! Knurling the slot end was the big "advancement" though, I have to shoot a picture of my finished product
Old 12-21-2021, 01:28 PM   #13
Anteek29
Anteek29's Avatar
Lol
Knurling is a great addition to a brilliant idea
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 12-21-2021, 01:34 PM   #14
rockfla
rockfla's Avatar
Proof that great Ideas come to stupid people as well, my first trial with them my fingers were a bit oily SO I couldn't get a good hold of them and the Light bulb "sort" of kicked on......Hence the slot cut into the end.......Second trial run went okay BUT I forgot to get the short slotted screwdriver......THEN THE 100W LED bulb kicked in and I thought, you BIG dummy Knurl the end and that will ADD to the convenience of getting them back out....AND Shortening the thread length!!!! I think the fire and wheel came about faster OR thank goodness those two weren't left up to me!!!!
Old 12-21-2021, 02:46 PM   #15
Lawson Cox
Lawson Cox's Avatar
I switched to studs to mount my distributors, years ago. I should have shortened them as well. Well, such is life.
Old 12-21-2021, 02:53 PM   #16
GaryU.
GaryU.'s Avatar
Used the same principle when replacing water pumps a few week ago, a few cut off bolts to get the pumps in place to make installation easier. Remembered to do this due to a distributor thread here years ago and found it works for pumps as well!
GaryU. is offline   Reply With Quote
Old 12-21-2021, 03:43 PM   #17
marko39
It works for many parts. A set of studs is used when installing 8 BA heads.
marko39 is offline   Reply With Quote
Old 12-22-2021, 09:35 AM   #18
38coop
I done the same thing when i put the transmission in my 49 Ford.
38coop is offline   Reply With Quote
Old 12-22-2021, 12:07 PM   #19
Bored&Stroked
Bored&Stroked's Avatar
I use studs on many of my builds - makes it a whole lot easier getting everything lined up. This is especially true if you're running any sort of "adapter plate" or CAM Button.
Also, I like the fact that I can put gaskets in their proper orientation (with whatever sealer is being used) and not have to try to juggle multiple parts, gaskets and cam buttons and attempt to get it all into place and the dang t-slot aligned.
Old 12-22-2021, 02:34 PM   #20
ford38v8
ford38v8's Avatar
I keep seeing these questions that have been answered so many times before, and have to remind myself that at one time they were fresh questions to most all of us, and that only the names have changed doing the questions and answers these days. We talk about the hobby not going forward with new enthusiasts, but it really is, as witness all the new names we see on the Barn, and new ones all the time. Merry Christmas to all, Old Timers and Newbies alike!
Alan
