#21 |
The Model T exhaust manifold would warp without the glands. Cast iron will expand when repeatedly heated. The exhaust manifold on the Model T was designed with more metal on the top so that it would warp down at the rear over time and the rear hole would not be aligned. The Model A exhaust manifold is a lot better design and will not warp nearly as much. Even so, some additional material was added in 1931. The glands are a carryover from the Model T.
#22 |
I have a waffle manifold. No warpage . I leave it on the year around but remove the housing in the summer.
#23 | |
Jim |
#24 |
Me too. Besides, I have an Autolite waffle manifold that hasn't sagged in all these years, it probably won't with my 5 or 6k miles per year either.
#25 |
Follow up report - the new exhaust manifold finally arrived (five days late, thank you FedEx), I dry fitted it with the old intake manifold and the assembly was straight and consistent within about 0.003". When I fitted the assembly to the block with glands installed but without the gasket it snugged down just fine. So on with the gaskets and tightened to 35 ft-lb. We'll see how it runs once I get the gooseneck back on (had a radiator leak I'm working on at the same time, took this opportunity to clean up the gooseneck.)
JayJay
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan (under reconstruction) 1931 Briggs S/W Town Sedan It isn't a defect, it's a feature! |
#26 |
#27 | |
JayJay
#28 | |
#29 | |
There's a decent amount of weight hanging off the intake and exhaust manifolds. You'll have trouble keeping them sealed against the block with your method. |
#30 | |
JayJay
#31 |
Mild steel or stainless? NAPA sells 1.5" OD aluminized mild steel exhaust tubing by the foot.
#32 |
#33 |
Same as Bill (#24) for me.
| Thread Tools | |
| Display Modes | |
