I don’t use them anymore. I also don’t have a manifold gasket leak problem. So I think it’s a waste of time. IMO
Me too. Besides, I have an Autolite waffle manifold that hasn't sagged in all these years, it probably won't with my 5 or 6k miles per year either.
Follow up report - the new exhaust manifold finally arrived (five days late, thank you FedEx), I dry fitted it with the old intake manifold and the assembly was straight and consistent within about 0.003". When I fitted the assembly to the block with glands installed but without the gasket it snugged down just fine. So on with the gaskets and tightened to 35 ft-lb. We'll see how it runs once I get the gooseneck back on (had a radiator leak I'm working on at the same time, took this opportunity to clean up the gooseneck.)
JayJay
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan (under reconstruction) 1931 Briggs S/W Town Sedan It isn't a defect, it's a feature! |
Be careful installing it as the ears on it are fragile. I have snapped them off more than once I think.
#6 | |
JayJay
#7 | |
#8 | |
JayJay
#9 | |
There's a decent amount of weight hanging off the intake and exhaust manifolds. You'll have trouble keeping them sealed against the block with your method. |
| Thread Tools | |
| Display Modes | |
