Old 11-13-2021, 08:52 AM   #1
Badpuppy
Default Re: Ignition Cable
What I don't like about the shorter cable is that it doesn't arc through the firewall properly after being clamped - points almost straight up. Wish i'd bought the longer cable, but I extended the armor with a length of 3/4" copper pipe and duct tape; worked ok. What I like about the skinny cable is it can be removed without pulling the distributor.
C'mon, it's not that hard to pull the dash. But wire is 16 ga. if you must.
Old 11-13-2021, 11:44 AM   #2
dmaxweb
dmaxweb's Avatar
How long have you had the shorter cable? I tried one probably 10 years ago and it was almost too stiff to bend at all. I've heard they are better now. The motor is out right now so I can't check the fit.
Per post #1 regarding removing the distributor - "Since the repro head stud clamps do not tighten down on the armored cable if I need to remove the distributor I can simply disconnect the wire and slide the armored cable out."
dmaxweb is offline   Reply With Quote
Old 11-13-2021, 05:02 PM   #3
Badpuppy
About 2 years now, Snyder's I think. It is a stiff bend, probably why it won't turn into the firewall easily.
I think he means disconnect inside and pull cable through the firewall. Easier to twist the cable out of the dist than spinning same off the cable. And my repro clamp holds it just fine.
