Re: How I pinstriped my 33 Tudor
Old thread, but I will add some tips I did not see mentioned here from the good Dr. Any time you want to do pin stripe like here, or a line for change of color, you pull the stripe tape off rite after you are done spraying while the paint is still wet. BE CAREFUL !!! but that way the wet paint will ooze out a bit and not leave a sharp edge. looks almost like it was done with a brush, and after its dry, some rubbing compound will erase all the sharp edge left from the tape line. We have not heard from the doctor for a while, hope all is well
