Old 11-05-2021, 04:45 PM   #1
1948F-1Pickup
1948F-1Pickup's Avatar
Default 8BA road draft tube OD
Or the ID of the hole in the manifold for the road draft tube ?
Looks like 1 5/8" or so?
Thanks.
1948F-1Pickup is offline   Reply With Quote
Old 11-05-2021, 06:24 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: 8BA road draft tube OD
Thanks.
Not sure the exact dimension, but if you're possibly looking for a way to block it off for a PCV Valve mod, a Dorman #555-023 freeze plug is a perfect fit. Link to the thread if you're interested. DD
https://www.fordbarn.com/forum/showt...pman+pcv+valve
Click Links Below __
T5 W/TORQUE TUBE
Old 11-05-2021, 07:45 PM   #3
tubman
tubman's Avatar
I believe he is asking about the size of the exterior tube on an 8BA type manifold.
Are they the same?
Old 11-05-2021, 07:50 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
Are they the same?
Tub is correct.....and I blew it once again! DD
T5 W/TORQUE TUBE
Old 11-06-2021, 05:54 AM   #5
marko39
It is 1 1/4" where it enters intake.
marko39 is online now   Reply With Quote
Old 11-06-2021, 10:58 AM   #6
1948F-1Pickup
Thanks for that. Greatly appreciated.
Old 11-06-2021, 12:00 PM   #7
Ross F-1
Ross F-1's Avatar
Do you need the tube?
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 11-06-2021, 01:12 PM   #8
1948F-1Pickup
Naw. When the engine gets back from H&H I'm going to install a ME Wagner PCV valve on it........ I refuse to buy an aluminum plug for $40 (Jamco) when I can machine a remnant piece of 6061 in 5 minutes.
Old 11-07-2021, 01:27 PM   #9
Karl Wolf
Karl Wolf's Avatar
or you could use a freeze plug, inverted, braze a fitting on it for the pcv...
Karl
Karl Wolf is offline   Reply With Quote
