Old 10-29-2021, 07:48 AM   #1
Mart
Mart's Avatar
Default Early Ford Crab Distributor. Strip and Reassembly. Tech at Mart's.
Hello. Welcome to a tech special from Mart's Garage.
Fords venerable Crab distributor. I take one apart and put it back together again. I share any little tips and care points along the way.
I hope this proves useful to anyone using this type of distributor.
I hope you like the new intro/outro segments. I had fun doing them. I got copyright strikes from the PIL music so have had to come up with something else.
Mart.
https://youtu.be/akhNZfl43YY
Old 10-29-2021, 10:18 AM   #2
theHIGHLANDER
Default Re: Early Ford Crab Distributor. Strip and Reassembly. Tech at Mart's.
Good stuff, well done, thank you.
theHIGHLANDER is offline   Reply With Quote
Old 10-29-2021, 02:23 PM   #3
done4
done4's Avatar
Send a message via Yahoo to done4
Thanks Mart!
Still smokin tires and cigars
done4 is offline   Reply With Quote
Old 10-29-2021, 04:23 PM   #4
drolston
drolston's Avatar
Good refresher.
Probably worth noting that modern gas is less prone to pre-ignition (pinging), so the "brake" can be adjusted to a light touch, just enough to damp or stabilize movement of the breaker plate. If you get a bit of pinging just as you open the throttle, but which goes away as the engine responds, you might go in one turn on the brake adjustment screw and try again. If the pinging continues after the initial throttle movement, you might need to back down one degree at a time (half a mark) on the timing screw.
If you are not sure what pre-ignition sounds like, advance timing one mark (move the little plate down) and road test. Just floor it as you get into second gear and listen to the engine. Repeat the advance until it "pings". It is a rapid rattle or knocking sound. Then back down on timing one mark (two degrees) and be sure the pinging is alleviated. This is the old school method of setting timing, and has the advantage of taking in all factors, such as fuel mixture, engine compression, altitude, etc.
Old 10-30-2021, 07:02 AM   #5
mfirth
Interesting indeed, as I MIGHT be looking for a 36-39 V8 come spring. Crabs & helmets are greek to me, so will need all the info I can get. Always a fun watch beacuse your narrating is fun to listen to. Thanks Mart, & cheers !!
mike
mfirth is offline   Reply With Quote
Old 11-04-2021, 11:52 PM   #6
1941Pony
Great video, thx for posting
1941Pony is offline   Reply With Quote
