Old 09-01-2021, 04:12 PM   #1
jrvariel48
jrvariel48's Avatar
Default What's my cubic inch?
If my bore is 3.328 with a 4" stroke, is my motor 278.xx ci or am I missing something?
Thank, Joe
jrvariel48 is offline   Reply With Quote
Old 09-01-2021, 04:20 PM   #2
Tony, NY
Default Re: What's my cubic inch?
278.36
Tony, NY is offline   Reply With Quote
Old 09-01-2021, 05:32 PM   #3
jrvariel48
jrvariel48's Avatar
Originally Posted by Tony, NY View Post
278.36
Thanks Tony!
Old 09-01-2021, 06:22 PM   #4
JSeery
JSeery's Avatar
It is the volume of a cylinder - (pi x r sq) X stroke OR (pi x d/2 sq) x stroke.
3.328/2 = 1.664 sq = 2.769 x pi = 8.699 x 4.00 = 34.795 which is volume of one cylinder so x 8 = 278.36
Old 09-01-2021, 07:57 PM   #5
Bored&Stroked
Bored&Stroked's Avatar
Or just do what I do . . . as I'm lazy . . .
http://www.wallaceracing.com/cid.php
Old 09-02-2021, 01:23 AM   #6
V8COOPMAN
V8COOPMAN's Avatar
This is the way I've been figuring it since I first started reading "Hot Rod Magazine" around 1961.
Bore X Bore X Stroke X .7854 X Number of Cylinders.
3.328 X 3.328 X 4 X .7854 X 8 = 278.36 Cu. In.
Click Links Below __
T5 W/TORQUE TUBE
Old 09-02-2021, 01:25 AM   #7
JSeery
JSeery's Avatar
Yep, there are always short cuts.
Old 09-02-2021, 03:10 AM   #8
jrvariel48
jrvariel48's Avatar
Thanks everyone!
Old 09-02-2021, 07:00 AM   #9
Ol' Ron
Ol' Ron's Avatar
3.328?????? 3.312= 3 5/16. 3.328 = 3 5/16 +.016. Strange bore?
Gramps
Old 09-02-2021, 10:15 AM   #10
tubman
tubman's Avatar
Cylinder wear?
Old 09-02-2021, 11:04 AM   #11
BrentButterworth
3.328/2 = 1.664 sq = 2.769 x pi = 8.699 x 4.00 = 34.795 is volume of one cylinder so x 8 = 278.36
DJ E Feezy
BrentButterworth is offline   Reply With Quote
Old 09-02-2021, 11:38 AM   #12
rotorwrench
rotorwrench's Avatar
I've seem pistons for 3 5/16" (3.3125") and 3 3/8" (3.375") but 3.328" not so much.
Old 09-03-2021, 03:46 AM   #13
jrvariel48
jrvariel48's Avatar
Gramps
Ron, Unfortunately, Gary (GOSFAST) is no longer with us for me to ask him.
I do remember him telling me he wanted to keep the bore as tight as possible and not remove to much material because it's a blower motor.
There's a note on my paperwork that says "8BA-Std Bore-Needs O/B (.040")
I hope this makes sense. Thanks Joe
Old 09-03-2021, 04:27 AM   #14
V8COOPMAN
V8COOPMAN's Avatar
3-5/16" (3.3125") is a standard overbore. IF your bores actually measure 3.328", that means that you're going to have roughly 0.016" PISTON CLEARANCE in each bore, which some of us are finding a little hard to understand.....IF the pistons ARE actually 3-5/16" pieces.
Are you sure that your bore isn't 3.228" rather than your stated 3.328? That would make sense as a +.040" oversize. DD
T5 W/TORQUE TUBE
Old 09-03-2021, 06:43 AM   #15
cadillac512
cadillac512's Avatar
Quote: "Are you sure that your bore isn't 3.228" rather than your stated 3.328? That would make sense as a +.040" oversize. DD"
...in which case your displacement would be 261.88 cu. in.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'30 Model A Speedster
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 09-03-2021, 07:27 AM   #16
Bored&Stroked
Sounds like it is just .040 over to me . . .
Old 09-03-2021, 11:23 AM   #17
rotorwrench
Pistons can be cut down and new ones can be custom made but Egge does make some larger oversizes than 3.3125" in the Mercury type 4-inch stroke. No telling what Gary came up with.
The Egge 3-ring pistons go up from .125" oversize in .010" increments.
Old 09-03-2021, 05:54 PM   #18
jrvariel48
jrvariel48's Avatar
V8, I believe you're onto something! I just found paperwork for my compression numbers from Gary and it says the bore is 3.228!
Thank you! Joe
Old 09-03-2021, 10:39 PM   #19
Ol' Ron
Ol' Ron's Avatar
I miss Gary, bought a Stricker assy from him a few years back, still running fine. Ses if your gona run allot of boost it's best to keep a thicker wall. 10 lbs of boos will do more for power then a large Overbore. Have a 294 blower motor putting out 235 hP on 4 lba od boost at 4500. Makes a nice street machine, Wonder what it makes a 5k, but he shut the beast down to sabe it. #$$$$$$$
Old 11-04-2021, 04:13 AM   #20
jrvariel48
jrvariel48's Avatar
Ron, I run this motor up to 5500 rpm with 8 lbs. of boost all the time!
Air/fuel is 12.3 at WOT at that rpm
Thanks
Joe
