Old 08-21-2021, 01:32 AM   #1
tubman
tubman's Avatar
Default Re: Relieved Block
Could you please share how you are able to get 11:1 compression on a relieved engine? Do you have a large displacement engine? Can you tell us how may ci?
Old 08-21-2021, 03:04 AM   #2
34PKUP
34PKUP's Avatar
Did not say he got 11:1 compression but has "11:1 Offenhauser heads".
Everything else is just 'puffery'.
34PKUP is offline   Reply With Quote
Old 08-21-2021, 08:23 AM   #3
tubman
tubman's Avatar
I'd really like to see what the O/P has to say.
Old 08-21-2021, 11:27 AM   #4
Vics Stuff
Vics Stuff's Avatar
As mentioned I am running 11:1 Offenhauser heads . With the relieved block I figure that I was in the neighborhood of 9:1 compression ratio. I was not wanting to build anything radical , but just wanted a old school looking engine. I am also using baffles in the center exhaust port , Fenton cast iron headers and 12 VDC electrical system.
It runs on regular pump gas and reliable to drive.
Vic
Vics Stuff is offline   Reply With Quote
Old 08-21-2021, 12:35 PM   #5
drolston
drolston's Avatar
Vic
Offy heads come with valve lift clearance specifications, not compression. Pretty much the only Offy heads around now are .400 and .425. Per the attached flathead compression chart, you can not get to 11:1 unless you are running a very big inch engine and .350 or .325 Offy heads.
Per the chart, my 284" factory relieved engine with .425 Offy heads has a compression ratio of 8.5, which is pretty close to optimum for a street engine. Runs strong with no pinging on regular gas and timing mark advanced 3 degrees.
