#6 | |
Super Moderator
Dash boards, floor shift vs. column can and were often swapped. Sounds like a '39 to me. The hood should have Ford on one side and Deluxe on the other. The springs could have covers as an option in 39. However, they would not have had a grease fitting in the cover(s). That would be later, '46 - '48. So, my guess is the springs were replaced with incorrect parts. Does your car look similar to the photo I've attached?
| Thread Tools | |
| Display Modes | |
