Old 07-06-2021, 08:58 PM   #1
37fatfender
Default Holley 390 CFM Accelerator Pump
I have a fuel leak coming from my accelerator pump, so I am going to replace the diaphram. I haven't taken the carb off the engine yet, so maybe I am ahead of my self. The engine runs well but the plugs are always black. I went online and there are to sizes to choose from a 50cc and a 30cc, which one do I use? I am leaning for the 30cc, the engine is a 276ci with a Schnieder cam and headers.
37fatfender is offline   Reply With Quote
Old 07-06-2021, 09:40 PM   #2
scicala
scicala's Avatar
Default Re: Holley 390 CFM Accelerator Pump
You want the accel pump diaphragm for 30 cc. The 50cc diaphragm is too tall for your carb. As far as the black plugs, take the front bowl off of the carb and see if it is wet from fuel on the vacuum side of the power valve on the inside face of the metering body. If so, the power valve is ruptured and needs to be replaced.
Sal
scicala is offline   Reply With Quote
Old 07-07-2021, 09:54 AM   #3
Terry,OH
Terry,OH's Avatar
Most likely the accel pump housing is warped, some sandpaper on a glass plate works well to get it flat again, if that is the problem.
Old 07-07-2021, 02:11 PM   #4
37fatfender
Sal and Terry thanks for the advise. Whats a good power value to use ? They are differents specs also, Right?
Old 07-07-2021, 02:21 PM   #5
19Fordy
19Fordy's Avatar
37: Is your Holley a 4150 or a 4160? What number is stamped on the choke plate? For instance, 8007. The Holey rebuild kit sheet will tell you what part # you need.
look here:
https://documents.holley.com/techlib...al_listing.pdf
and here:
https://www.google.com/search?q=what...hrome&ie=UTF-8
Old 07-07-2021, 03:17 PM   #6
backrodebob
backrodebob's Avatar
the power valve your looking for is a 6.5! just changed mine!
backrodebob is offline   Reply With Quote
Old 07-07-2021, 03:41 PM   #7
37fatfender
The air horn on my carb is stamped 8007 and below that is 1559. So i need a rebuild kit for a 8007, what is the significance of 1559? No 4150 or 4160 on the carb.
the rebuild kit appears to be 37-720 and it is a 4160 series carb. Thanks 19Forty
Old 07-07-2021, 04:14 PM   #8
37fatfender
Shame on me ! ...... what's leaking is the Vacuum Secondary Diaphragm, not the accelerator pump...... !
Old 07-07-2021, 04:41 PM   #9
scicala
scicala's Avatar
The 1559 number is a date code. Your carb (8007) is a 4160 model. That is never stamped or cast on the carb. The 4150 model had a secondary metering body similar to the front one.
That is very odd and almost impossible to have fuel leaking out of the secondary diaphragm, since fuel can't get into it. Been doing Holley carbs for over 50 years, and never saw any fuel in the diaphragm housing.
Sal
Old 07-07-2021, 05:04 PM   #10
37fatfender
Hmmmmm.... Will let you know.
Thanks, Sal
Old 07-07-2021, 05:25 PM   #11
Bored&Stroked
Bored&Stroked's Avatar
Sal is 100% correct (as usual!) the secondary diaphragm only sees vacuum and it actuates the secondaries on the outside . . . no fuel anywhere near it.
The accel pump has a small rectangular diaphragm inside a much smaller rectangular housing on the bottom of the fuel bowl.
As noted, you may have a blown power-valve . . . that will cause things to be really fat and rich. Did the carb every work correctly - are these recent issues?
Old 07-07-2021, 08:17 PM   #12
4dFord/SC
4dFord/SC's Avatar
A noticeable smell of raw gas after the engine is shut down can be an indicator of a blown power valve.
4dFord/SC is offline   Reply With Quote
Old 07-09-2021, 02:56 PM   #13
37fatfender
I pulled the card today, Yes, it is leaking from the Accelerator Pump area. I am waiting for the rebuild kit before I tear it down. Long ago when i put it together I marked the fuel bowl with a marker and noted "50", I am assuming that's the jet size I installed, any thoughts on the "50's" jets?
Old 07-09-2021, 03:14 PM   #14
scicala
scicala's Avatar
The original primary jet size for a 8007 390 Holley is #51. I would stick with that. Also, a #50 is only .001" smaller (2% smaller).
Sal
Old 07-09-2021, 03:15 PM   #15
37fatfender
Spark plug photo!
Old 07-09-2021, 05:03 PM   #16
Crankster
Crankster's Avatar
Are those spark plugs the standard heat range? Were they removed after a highway "chop"?
Getting the correct "pump squirt" will help, as will correct jetting and power valve. It helps to know what engine manifold vacuum numbers are at steady cruise and on slight hills &c.
There is some seemingly contradictory information on how to or what power valve # to select which I attribute to the intended audience. Drag racing or semi-performance engines versus stock stock street applications.
It's important to realize that engine vacuum is the only thing holding the power valve closed. The power valve should remain closed at all times other than demand for power, acceleration, under load etc. If the wrong value is selected, or it is defective, it will constantly dribble fuel.
There is also a correction factor applied for altitude or local elevation, a PV suitable for Iowa or Kansas is not going to work for high country Colorado. Plugs are really difficult to read with modern gasoline and will ordinarily look pretty lean when they are correct. The old spark plug reading color picture charts aren't really that useful anymore.
Make sure, the power valve is not open during flat ground cruise, not even a little. Then, jet up or down as necessary.
Crankster is offline   Reply With Quote
Old 07-09-2021, 05:27 PM   #17
19Fordy
19Fordy's Avatar
37fatfender: What engine are you running? Is it stock? Do your sparkplugs have enough reach?
Old 07-10-2021, 03:07 PM   #18
37fatfender
19Fordy,
The engine is a 8ba, Merc crank, 276ci, Schnieder cam 355 lift. Holley 390cfm carb. Edelbrock 952 4bbl intake with a 1 inch riser. Note I run the carb backwards to accomodate the 40 gas peddle linkage. The head are early version Edelbrock 32-48 modified water passages for the 8ba block. The plugs I have in it at present are NGK FR4, which are comporable to Champion RC12YC that Edelbrock recommends for use in these heads. I believe the reach is correct, and if I remember, which is getting harder to do these days........ I opened up the plug area before I installed the heads.
Old 07-10-2021, 03:51 PM   #19
19Fordy
19Fordy's Avatar
37: Thanks for the feedback. That FR4 Plug has a 3/4 inch reach which is good.
On my 239 cu. in 8BA with Motor City Flathead early style heads. I am using NGK VR4 2635 plugs that also have a 3/4 in. reach. Also running a 390 Holley with #51 jets.
No problems. Wonder how "my" plugs would work in your engine.
Take a look at this video and see if it might help you. I replaced the slotted screw with an allen head screw so it can be adjusted with the Holley carb on the car.
https://www.youtube.com/watch?v=b8ROjrGAH2I
Old 07-11-2021, 09:13 AM   #20
5851a
Just out of curiosity what distributor are you using with the 390 Holley?
5851a is offline   Reply With Quote
