Old 07-03-2021, 03:40 PM   #1
vern hodgson
Default Dead in the road
Left garage on a four mile cruise, two miles in, engine cuts out and restarts happened second time, restarted, third time no go, no lites, no horn but turns over. Where to look, terminal box, switch?
vern hodgson is offline   Reply With Quote
Old 07-03-2021, 04:18 PM   #2
Bob from Northport
Bob from Northport's Avatar
Default Re: Dead in the road
Check the ignition wire that runs from the starter to the generator for power. Is there a fuse in the engine compartment??
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 07-03-2021, 05:54 PM   #3
vern hodgson
No fuse, will check wire later today, to hot, to tired. Thanks.
Old 07-03-2021, 07:29 PM   #4
Doug Linden
Doug Linden's Avatar
If you have working.a test light, start at the terminal on the starter switch and follow the wires to see where the light stops. That should give you a answer where the problem is located.
Doug Linden is offline   Reply With Quote
Old 07-03-2021, 09:11 PM   #5
GRutter
GRutter's Avatar
If no fuse as Bob suggested, then jump the two terminals together in the firewall junction box. That will bypass the Amp Meter. Repro meters are failure prone, and fits your description of no lights, no horn, no ignition, but turns over.
GRutter is offline   Reply With Quote
Old 07-03-2021, 10:01 PM   #6
vern hodgson
First thing in the am,thanks
Old 07-04-2021, 06:12 AM   #7
Patrick L.
Patrick L.'s Avatar
I carry an old distributor primary cable end with the armor stripped off and a spring clip attached.
A jumper lead as GR suggests is a good thing to carry around.
Old 07-04-2021, 07:38 PM   #8
burner31
burner31's Avatar
I have one also
Back in the day the cops would pinch you for having one of those
Keith
Shawnee OK
'31 SW 160-B
Old 07-04-2021, 10:38 PM   #9
warrene
Yea' ... repro' ammeters are JUNK, I finally found an old one on eBay, end of problems.
warrene is offline   Reply With Quote
Old 07-05-2021, 03:12 AM   #10
old31
Just so I undestand. Do you mean you are putting a jumper on both the driver and passenger side of the dogbones?
old31 is offline   Reply With Quote
Old 07-05-2021, 05:25 AM   #11
Patrick L.
Patrick L.'s Avatar
Originally Posted by burner31 View Post
I have one also
Really ? Interesting. I didn't know that.
Old 07-05-2021, 02:17 PM   #12
Gary WA
Gary WA's Avatar
Is your road still dead?
www.whidbeymodelaclub.com
Old 07-05-2021, 05:23 PM   #13
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
It must be”stinking to high heaven” by now.
Seriously, any luck yet?
Old 07-05-2021, 05:37 PM   #14
Fred K OR
May be coil. I had similar problem and it was coil. Just guess.
Fred K OR is offline   Reply With Quote
Old 07-05-2021, 09:44 PM   #15
GRutter
GRutter's Avatar
Yes - across both terminals in the junction box. If you look at the wiring diagram, jumping the two terminals does nothing more than eliminate the ammeter.
Old 07-06-2021, 08:09 PM   #16
vern hodgson
So… dropped t box cover, no juice on either terminal, inspected wires all seem ok, laid a wrench across t box studs and hit the horn button. She sounded off like a new bride on her honeymoon. Replaced ammeter. Now to find an original.
Old 07-06-2021, 08:10 PM   #17
vern hodgson
So a big THANKS to every one. What a feeling to conquer the dreaded electrical monster
Old 07-06-2021, 10:02 PM   #18
GRutter
GRutter's Avatar
Glad you got it solved. Just follow the wiring diagrams. Model A wiring is relatively simple even for the 'electrically challenged'. It's not a monster - you just keep nibbling at it until it you nail it.
