Old 05-14-2021, 05:18 AM   #1
flathead48
Default Rotors
I have purchased about 1/2 dozen rotors for crab distributors from 3 different suppliers in the past 3 weeks. They all are loose on the shafts, I have tried them on 5 different distributors and same results. I installed one and when I went to start the engine the rotor slipped off enough to hit the inside of the cap and broke in half. Since the rotor and shaft turn as one I don’t see how the shaft can wear. A older rotor about 15 years or so old has to be practically preyed off. In my limited knowledge I am guessing these rotors are made with mounting hole to large. Has anyone else had a problem ? Is there a remedy?
Thanks, Rick
flathead48 is offline   Reply With Quote
Old 05-14-2021, 06:17 AM   #2
corvette8n
corvette8n's Avatar
Default Re: Rotors
Rick: I’ll be watching for an answer as I have a crab distributor I may put on my ‘41
Try barnfind he may have an nos one.
https://www.fordbarn.com/forum/priva...=newpm&u=11230
Old 05-14-2021, 06:30 AM   #3
Veeder
Default Re: Rotors
Roick
Can you post one pic?
Bob
Veeder is offline   Reply With Quote
Old 05-14-2021, 06:49 AM   #4
deuce_roadster
deuce_roadster's Avatar
Default Re: Rotors
I would think if you pushed a thin piece of paper down over the shaft wth the rotor it could take up the slack. I think I have seen a thin spring metal piece on the end of a distributor shaft too.
Old 05-14-2021, 08:19 AM   #5
barnfind08
Default Re: Rotors
I have nos ones
barnfind08 is offline   Reply With Quote
Old 05-14-2021, 09:29 AM   #6
tubman
tubman's Avatar
Default Re: Rotors
Originally Posted by barnfind08 View Post
I have nos ones
Fred to the rescue!
Old 05-14-2021, 09:48 AM   #7
rotorwrench
rotorwrench's Avatar
Default Re: Rotors
The early and late 8BA family of engiones as well as the later ford tractors used a flat spring or a clip to fit the rotor tightly to the shaft. These were either the 7RA-12213-B or the 8BA-12213 respectively. I wonder if the correct rotors are being sold for the older crab or rabbit ear type distributors. The 7RA-12200 and the 59A-12200 rotors do look a lot alike.
The true crab rotor of 1942 was the 21A-12200 is a bit different.
Old 05-14-2021, 11:38 AM   #8
drolston
drolston's Avatar
Default Re: Rotors
I shimmed with a piece of paper for a snug fit of the rotor on the shaft. Be sure to spin the rotor with the cap on before you install the distributor, to be sure the rotor does not contact the spark plug wire connectors inside the cap. if you get any contact, it is probably because the cap is not on perfectly straight or completely seated.
In most cases you have to install the distributor and then the cap. Once you get the cap on and snapped, tap it down firmly with a leather or plastic mallet, or a hammer with a piece of wood as a cushion.
Here is what happens if the cap is not seated perfectly straight. The car might start and run but very badly. This was part of my winter of ignition discontent.
Old 05-14-2021, 12:05 PM   #9
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Default Re: Rotors
By the way guys i have a bag of new old stock retaining clips ...let me know if ya need one ......
Other wise use a cent punch to peen the rotor shaft then install the rotor ......???????????:d
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 05-14-2021, 12:11 PM   #10
BUBBAS IGNITION
Default Re: Rotors
Clip pic
[email protected]
Old 05-14-2021, 05:19 PM   #11
V8COOPMAN
V8COOPMAN's Avatar
Default Re: Rotors
Wonder JUST HOW MUCH the Ford house would charge ya for ONE of these clips.....IF they even have a box of 'em on the shelf now-a-days? DD
Click Links Below __
T5 W/TORQUE TUBE
Old 05-14-2021, 05:30 PM   #12
Rudolph
Rudolph's Avatar
Default Re: Rotors
I got a bob drake rotor that needed a lot of shortening to fit, put a NOS rotor with a bob drake cap and it collided and bent the brass bit of the end
Rudolph is offline   Reply With Quote
Old 05-14-2021, 05:32 PM   #13
Rudolph
Rudolph's Avatar
Default Re: Rotors
I drove 120 miles with a twisted rotor like this, it burnt holes in the cap but seemed to run ok
