Old 05-11-2021, 07:59 AM   #1
adileo
adileo's Avatar
Default 52 F1 tranny
Hi guys
My truck has a 3 speed top loader, probably from a 48 F1. Lately when trying to shift out of 1st gear the whole truck bucks, bangs and difficult to pull out of gear. I can start off in second with no problem and shift into third no problem.
On occasion this issue has also happened in reverse. But not as often.
Thoughts?
Thanks
Andy
1952 F1
adileo is offline   Reply With Quote
Old 05-11-2021, 11:15 AM   #2
alanwoodieman
Default Re: 52 F1 tranny
clutch adjustment?
Old 05-11-2021, 11:39 AM   #3
1948F-1Pickup
1948F-1Pickup's Avatar
I had to go through EVERYTHING to get mine manageable. Clutch linkage play, engine mounts, worn out pedal bushing..... etc.
Took care of about 90%. My honest opinion is the slight remaining issue when the clutch is hot is the clutch material itself is crap.
1948F-1Pickup is offline   Reply With Quote
Old 05-11-2021, 12:30 PM   #4
adileo
adileo's Avatar
Thanks guys. Free play seems about right. Guess I’ll have take it to a pro.
Thanks
Andy
1952 F1
Old 05-11-2021, 05:20 PM   #5
Ross F-1
Ross F-1's Avatar
I wonder if the mainshaft bearing is on its way out? i.e., things are loose back in the 1st/Rev area.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 05-11-2021, 06:51 PM   #6
rotorwrench
rotorwrench's Avatar
If it is the light duty 3-speed of old then the low gear is unsynchronized and slides on the main shaft only when shifted. It either goes into the reverse selection or it goes into 1st gear. If the low/reverse gear is moving around, cluster gear is moving around, or the main shaft is moving around too much, there could be a problem. The clutch definitely has to be doing its job when releasing too as was mentioned. The shift tower may also need inspection of the tip of the shift lever and the slots it fits into. Make sure there is plenty of lube in the case. That's what allows the cluster gear & main shaft to slow down when you depress the clutch control pedal.
There can also be a problem with the pilot bearing. If it doesn't allow the input shaft to move free of the flywheel with the clutch released, you will have a problem.
Old 05-12-2021, 08:32 AM   #7
chap52
chap52's Avatar
What Ross F-1 said... Chap
Old 05-12-2021, 11:56 AM   #8
adileo
adileo's Avatar
Ok thanks guys! Plenty of GL4. It’s my daily driver and all you described is over my ability. I’ll get it to a pro.
Thanks
Andy
1952 F1
Old 05-12-2021, 01:27 PM   #9
tubman
tubman's Avatar
C'mon, if it's just that you think you lack the skill, that's probably not the problem. 25 years ago, I bought a '46'48 transmission at a local swap, a '39 case and top from Hemmings, and as many new bearings and synchronizers as I could find. I had the transmission book Speedway used to sell (there are much better ones available these days), and set to it. There is really not much to these transmissions, and in a few days on and off again work, I had a transmission ready to go. I put it behind a 276" Merc in my '36 3-window, and never had a bit of problems with it. (Don't ask me about the rear axle.)
And then you'll have a new skill in your bag of tricks. (Or maybe I was just lucky.)
Old 05-12-2021, 02:22 PM   #10
adileo
adileo's Avatar
Denny
What can I say except, you da man….
Gonna be getting pretty hot down there in Florida, come on up to NJ, cool down, have a beer or two and help fix this ��
Thanks
Andy
1952 F1
Old 05-12-2021, 02:34 PM   #11
tubman
tubman's Avatar
Damn, I'm already back in Minnesota, or that would be a plan!
Old 05-12-2021, 06:33 PM   #12
rotorwrench
Mac VanPelt's early Ford light duty transmission book is very good. It's a good idea to expect to use a press or some other form of bearing pullers for stubborn parts but the difficult part is getting the old style snap rings off. Mac VP has a very good snap ring kit that has the correct thickness rings and they can be removed easily with snap ring pliers.
Removing and reinstalling the transmission is the hardest part.
Old 05-12-2021, 08:31 PM   #13
tubman
tubman's Avatar
"rotorwrench" is right on. I should emphasize that my post was not to point out any special skills or talents I have, but to emphasize that these transmissions are quite simple and can be successfully rebuilt by anyone with a minimum of skills, but the ability to to careful work. I would dare say that parts are easier to find these days than they were when I did mine.
I sure wish I had known about Van Pelt Sales when I did mine.
